Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
FNG
I've bought a 56 truck that's has a Camaro front clip and 10" rear end. How do I find out the year of each one? Your help is appreciated
#2 |
I think the 67,68,69 is rear steer,70-79 front steer with 2 piston caliper,after that think calipers are small one piston.
#3 |
Old School HAMBer
IIRC, pre 70 Camaro stubs use a "double" crossmember and are rear steer as George pointed out. Nova stubs are rear steer up through 73, I believe.
Did you mean "10 bolt" rear? There are 2 main variations. If the cover is almost perfectly round, it's an "early" 10 bolt. If it has a squared off cover, it's more likely a 78 and up "metric" axle.
__________________
Words of Wisdom from an old master... |
#4 |
Pictures of the clip and steering box location will help identify the clip. Picture of the rear end cover will help identify the rear.
#5 |
Old School HAMBer
67-69 camaro and 68-74 nova are rear steer. Later are front steer.
There are at least three variants of the 10 bolt rear. Early ones were the 8.2", starting around 71 they got the 8.5". The 7.5" was not used in cars that had front subframes.
#6 |
Senior Member
70 to 72 camaro clips have different size upper control arm bushings. 73 to 81 are the same size.
#7 |
FNG
Thanks for the help. I appreciate your help.
#8 |
FNG
Thanks for the info
#9 |
Senior Member
i had a 7.5" 10 bolt in my apache. there total shittt. i have a camaro clip in it as well, it gives you a ton of options with the front suspension whether it be bags or what have you. hard to beat really. do yourself a favor and ditch the 10 bolt if its a 7.5"
#10 |
FNG
Why didn't you like the 7.5"?? I'll check this out, thanks
#11 |
FNG
I finally got under this truck and found it to be a 8.5" 10 bolt rearend. 41 on the ring and 17 on the pinion. Man that's low. Thanks fro your help.
#12 |
FNG
it turned out to be a 8.5" 10 bolt rearend. With a 2.41 gear ratio. Thanks for your assistance.
#13 |
FNG
Your illustrations helped a great deal. I have an 8.5" 10 bolt with 41 teeth on the ring and 17 on the pinion. Any idea what this might have come out of? Maybe a truck?? thanks for your help.
#14 |
#15 |
Alliance Member
There will also be an axle code on the top of one of the housing tubes near the center chunk. That could help figure out the origins, because I'll bet they both came from the same car.
__________________
Only the good die young. If you want to live a long time, be an asshole. " I am attempting madam, to construct a Nemonic memory circuit using stone knives and bearskins " |
#16 |
Old School HAMBer
Location: Upstate New York, watching my New Yorker Rust
2.41 is a highway gear. It probably came out of the same Camaro/Firebird the front clip did. Is it 61" or so wide?
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage I have old cars for sale. PM me or check the classified. |
#17 |
FNG
Het thanks. I got those numbers/”letters. Have any direction i can go to to find out what they mean?? Thanks again
#18 |
FNG
Yes it's 61". Thanks
#19 |
FNG
Ok I got the info. On the rear end is 1148. On the control arms is (passenger side) G22J8R and on the drivers side is J7118L. Have any ideas??
#20 |
FNG
Re: Camaro clip
Ok I got the info. On the rear end is 1148. On the control arms is (passenger side) G22J8R and on the drivers side is J7118L. Have any ideas?? |
| Thread Tools | |
| Display Modes | |
