Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Alliance Member
I would think that Moser axles would hold up on a street car with a few occasional runs down the strip but we'll see.
HR, it sure has been fun watching you work out your "issues". LMAO! |
#22 |
Senior Member
We ran 31 spline Moser's in a 9" w/4:11 gears in a 56 Chevy with radail tires on the street and a couple drag passes with a 485HP 383 stroker motor and a 350TH and it never had an issue!
#23 |
And if they were drag radials, those are sticky som'bitches!
#24 |
Alliance Member
Thanks for the help fellas.
#25 |
Tech Editor
For a decent starting point - look at late-60s to late-80s Ford 4x4 trucks and broncos. They will quite often have 31-spline, 3.50 ratio, traction-lok rears. Look at the outside axle flange - if it has 3 holes in a straight line, chances are it's a 31-spline axle (unless you're looking at big land yachts from the early-mid 70s or disk brake rears). If it has a big open double-D, it's a 28-spline axle.
When I used to go junkyard trawling, I'd just look at the axle end and if I saw the 3-holes, I'd then make the effort to find the tag on the rear...otherwise, I didn't waste my time getting dirty.
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch! T5 Tech |
#26 |
Grenade Inspector
Ford quit using the 9 in. in trucks in 82, cars Most cars 77.
#27 |
Grenade Inspector
Call Johns 9 inch next time 1-800-332-3450
| Thread Tools | |
| Display Modes | |
