Technical 7.00-16 bias ply wheel width
Discussion in 'Traditional Hot Rods' started by fourspd2quad, Mar 18, 2014.
  1. fourspd2quad
    fourspd2quad
    Is anybody running 700-16 size tires on 4.00 wide wheels (‘40 ford)? Coker recommends 4.50-5.50 wide wheels but I was hoping to run them on my 40’s<O:p</O:p
  2. F-6Garagerat
    F-6Garagerat
    You will get 100 people that say they run them on 4" wheels with no problem. You'll get another 100 that will say don't do it. To me it looks like the tread surface starts to get an arc to it with the 4" wheels. It's only 1/2" but ya gotta figure, they are the tire people, they recommend 4.5 minimum for a reason. I've run 750's on 4 1/2's. My current ride has 750's on 16x5" Merc wheels. I like the look of the tire on the 5" wheels.
    99 to go :)
    studog51 likes this.
  3. olskool34
    olskool34
    I run 7.50-16's on stock 35 ford wires. They are 4 inches. 5 years now and no issues.
  4. 7.00's are a bit wider than 7.50's and they seem to fit 4 1/2" rims very well. Just did a set and happy with the fitment.
  5. Dreddybear
    Dreddybear
    I run 750 16x4 no Prob. I have several friends with 700 16 x 4 also no prob.
  6. F-6Garagerat
    F-6Garagerat
    See what I mean? ;)
  7. fourspd2quad
    fourspd2quad
    Thanks for all the replies. I guess the potential issue may be uneven tread wear if the tread is slightly bulged?
  8. hilltopgaragede
    hilltopgaragede
    from Delaware
    The 4.50 run perfect on 4" rims. They wear even and look sweet with no bulge.
    Gives the skinny up front look, if that's what you want.
  9. scrap metal 48
    scrap metal 48
    You probably won't run much air pressure in the 7.00/7.50's anyway so I think the tread wear issue is not much...
  10. MY $.02
    Seems like I was in this thread before but I looked back and didn't see it sooo,
    I've been running 7:50-16's on 35 wires on this A for 11 years, 3 different sets and never had a problem, and I know others who also have.
    Do it unless you are building a drifting car!!!!
  11. cs39ford
    cs39ford
    I run coker 650x16 and 750x16 on stock 39 ford wide five wheels since 1990 on my second set of tires no problems
  12. F-6Garagerat
    F-6Garagerat
    Wasn't the OP asking about 750's?
  13. clem
    clem
    Or the tyres could bounce of the rims if you hit a pothole! - Stick with 5" rims minimum.
  14. tommy
    tommy
    I've had 700s and 750s on stock Ford wheels with no problems at all. The worry warts and nit pickers will argue but don't fret it you'll be fine. Life is too short to worry about it.
  15. fab32
    fab32
    Gospel !! As to the "life is too short to worry about it" your talking to experts here when you refer to Tommy and I. At just shy of 70 I can tell you a lot of things I fretted about 30 years ago don't even qualify for a fleeting thought today.:eek::D
    Frank
  16. CAMSHAFT666
    CAMSHAFT666
    750-16 on a 4 inch rim on mine...
    Haven't run it yet but I've seen alot of cars with this combination...
  17. bgaro
    bgaro
    you'll get a little more "dome" to the tread, but as said tread wear should be fine. run 'em.
  18. clem
    clem
    Less/incorrect tyre pressure =faster tread wear.
  19. 345winder
    345winder
    no.. he wasn't, 7.00's was the question :)
  20. Thank you. Exactly why I gave my experience with 7.00's. I also agree that 4" will work just fine.
    All good.
  21. fourspd2quad
    fourspd2quad
    Thanks for all the replies. I going to run the 700's on the 40's
