Olds 350 Blower Manifold
Discussion in 'The Hokey Ass Message Board' started by 72OLDS, Feb 23, 2010.
  1. 72OLDS
    72OLDS
    from Orangevale
    I have a lot of free time on my hands these days and I'm thinking about supercharging my Cutlass. I've been looking through all the parts I need but the one thing I can't seem to find is a manifold. Anyone know of any inexpensive ones or a manifold that can be modified to suit my needs?
  2. joe_padavano
    joe_padavano
    "Inexpensive ones?"
    HAHAHAHAHA Good one.
    The only dedicated Olds blower manifolds I have ever seen were cast by Sharp in the 1960s, as used on the Hurst Hairy Olds. All the aftermarket Olds blower setups use fabricated manifolds. Usually they start with an Offy dual quad single plane manifold. The carb flanges are milled parallel to the crank centerline and a thick aluminum plate is bolted or welded to the manifold to mount the blower.
  3. 72OLDS
    72OLDS
    from Orangevale
    So probably not worth it? Stick with building internals and rear end?
  4. Phil1934
    Phil1934
    I think he had one for B&M back in the day
    Dave Smith Engineering
    25078 Road 196
    Exeter, CA 93221
    559-562-3500
    Fax:559-562-0100
  5. flamedabone
    flamedabone
    Blower Drive Service stocks a manifold for the 350 Olds. Part # BDS8506. $1066.99.
    Some blower shops (Hampton, Mooneyham, etc.) will convert your aluminum manifold to 4-71/6-71 with a bit of maching work and a welded plate. Most likely less than the price of the BDS unit.
    Good luck, -Abone.
  6. ***Area-51***
    ***Area-51***
    from Ohio
    offenhauser 360* manifold have been converted to blower manifolds for olds...
  7. 333 Half Evil
    333 Half Evil
    Dude, you come on here with a 1972 cutlass looking for advice, parts etc. You never did an intro, and your car is not what this forum is about. In you carb running rich post you claim you are broke that is why you are asking for suggestions so you can fix it yourself. Well if you are broke, you sure as hell can't afford a blower. Do yourself a favor and find a muscle car, old, or cutlass forum to hang out on.
