hi, i,m trying to put dummy spot lights on my 1950 ford, i pulled the window frame off to see if i can get the bolts though.it is blocked off and you cant get to put nuts on the bolts that hold the lights on.is there a other way to do it?
[is that self tapping screws, or just drill a small hole then screw them in? QUOTE=55 Ford Gasser;9638359]I used sheet metal screws on mine. Been that way for nearly 20 years without any problems.[/QUOTE]
I drilled a small hole and used stainless screws for the counter sunk holes in the spotlight base. I think the screws came with the lights but that was a while ago.
UOTE=tudorfritz;9638402]Yep just use screws that came with them View attachment 2174216 Posted using the Full Custom H.A.M.B. App![/QUOTE] thanks alot guys,,, then thats how i,ll do them,this is a great site, thanks h.a.m.b.
