1978 Quadrajet idle mixture adjustment?
Discussion in 'The Hokey Ass Message Board' started by atomickustom, Apr 24, 2006.
  1. atomickustom
    atomickustom
    The stock Quadrajet on my 1978 350 has no idle mixture adjustment screws! I didn't notice this until I'd already gone to the trouble of cleaning the carb, bolting it onto my new manifold, and adapting all my linkages, etc. It runs fine, but I'm sure I could smooth out the idle a bit more if I could rich it up just a teeny bit.
    There are just silver metal plates filling the round holes where the screws would normally be. Are these just covers? If I pry them off, will I destroy my carb, or will I find adjustment screws patiently waiting for me to adjust them?
    I DID try to search to see if this has already been covered. If it has, please just post a link to the old discussion.
    Also, I know that a 1978 Quadrajet isn't exactly "traditional" and don't need anyone to remind me. The entire running gear in my '53 Chevy is from a donor car (1978 Impala wagon = CHEAP), and I'll take "cheap" over "traditional" any day. You wouldn't believe how many parts you can use off of one good donor car!
  2. OLDSKEWL61
    OLDSKEWL61
    There Are Just Covers I Ussally Jusy Drill A 1/8 In Hole From The Bottem Up Angle Toward The Front And Stop Before You Go Through All The Way And Drive Out The Cap With A Punch.
    Good Luck
    Rayday
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    25 years ago, all of the parts stores sold "modification kits" that came with a hole saw to cut out the plugs, and a special adjusting tool, since the ends of the mixture screws resemble a clutch head, like '40s and '50s Chevies are held together with. Thexton made such a kit, but I don't know if they still do.
  4. Flatman
    Flatman
    You might be able to grab the screw head with some small needle nose pliers, once you get the covers off :D
    Those Q Jets were great carbs, huge secondaries:eek:
    Flatman
  5. 53sled
    53sled
    from KCMO
    Lisle tool and maybe Motormite sell q-jet tools with the funky end. Drill a small hole, run a screw in, pop out.
  6. atomickustom
    atomickustom
    Thanks for the info, everyone. I'll be drilling and popping soon.
  7. bigdog
    bigdog
    Those mixture screw plugs might be hardened steel- they were on the one I just did. Drill bit won't touch 'em if they are. I went and dug out the instructions for removing the plugs.
    1.invert throttle body
    2. place punch between two location marks over idle mixture plug
    3. break out throttle body to provide access to the hardened steel plug, drive plug out
    4.late models-cut 2 parallel slots on either side of the location marks using a hacksaw. slots should not exrend beyond 1/8 inch past the marks
    5. position a flat punch at a 45 degree angle between the ends of the saw marks in the throttle body, drive the punch between the slots causing the slug to break off.
    6. hold a center punch in a vertical position and drive it into the steel plug, then angle the punch 45 degrees and drive the plug out.
    Fun, huh? always loved beating on carburetor with hammers.
