how do i wire a GM 3 wire alternator
Discussion in 'The Hokey Ass Message Board' started by SpeedRacer2002, Sep 30, 2004.
  1. SpeedRacer2002
    SpeedRacer2002
    can anyone tell me where all the wires go??? and i know i can get a 1 wire but i have a brand new 3 wire and i want to use it on this car.....
  2. Brickster
    Brickster
  3. BigDdy31
    BigDdy31
    Good link man, thanks.
  4. For the common garden variety Delco 3-wire in a typical non-pigtail hotrod application, do this...
    The big wire(pole with nut) is obviously the power and goes to starter pole, headlight pole, ign pole, whatever, depending on how youre wired. The next two say '1' and '2' and are spade connections. One of them('2' I think) you simply loop over and connect to the big wire pole, thats all. The other one('1' I think) goes to the switched side of the ignition, or you can run to the ign side of the coil, doesnt matter, but must be turned on and off with ign. Now be sure to do this(or once you start the car you cant turn it off without yanking out something), inline on this wire install a one-way resistor, like a zenor diode from Radio Shack so that current can only flow from the switch to the alt.
  5. Dooley
    Dooley
    from Buffalo NY
    I ran mine like this.
    Big wire is wired through my ammeter to the starter.
    In the plug in one, #1 goes to the ignition, the other #2 loops over the the batt post on the alternator.
  6. moondisc
    moondisc
  7. jerry
    jerry
    you can also run a small light buld in line on the wire from the igntion switch. it ahs enough resistance to keep the motor from running on. factory does the same with the idiot light.
    jerry
  8. Mostly right BUT on that two wire plug in #1 term loops to the back of alt[BATTERY PLUS] with a heavy wire.
    NUMBER2 TERMINAL HOOKS TO ACCESSORY SIDE OF IGN SWITCH-=DONE
    deathrowdave likes this.
  9. moondisc
    moondisc
    [ QUOTE ]
    [/ QUOTE ]
    That's how I hooked it up in my 54 Merc.
  10. SpeedRacer2002
    SpeedRacer2002
    awesome info guys thanks much...
  11. Deville1904
    Deville1904
    Sorry for diggin this thread up from beneath the grave. Just that it seems like everyone seems to have a different suggestion for the proper wiring method on a 3-wire alternator.
    I was running a single wire in my 54 cadillac but that turned out to be very unreliable for obvious reasons.
    So now im looking for a 100 amp plus three wire but I want to make sure I wire it properly the first time.
  12. AllSteel36
    AllSteel36
    What's posted above is how to "make" a single wire from a 3 wire Alternator.
    Go to madelectrical.com, there's good diagrams...the down side of wiring it (3wire) as a one wire alt, you usually have to speed the engine up to get the alternator to start charging
  13. X2 on Mad Electrical
  14. Da Tinman
    Da Tinman
    Any 12v ignition hot can be used on the #1 post, I use the resistor side of the starter, with a diode. Works perfectly.
  15. enjenjo
    enjenjo
    from swanton oh
    If you jump the no.2 wire to the batt wire on the back of the alternator, it will work, but you are setting up a chronic low charge condition. The number 2 terminal is used to sense system voltage, and if it is seeing 12.5 volt at the alternator it shuts it down, when the rest of the system may be seeing only 11.8. So it is best to connect that at the junction where most of the systems in the car get their power. the fuse box is a good point, as is a firewall junction. So if you are running a basic system, not many accessories, it's ok to jump the terminal, but if you are using a lot of power, better rethink it.Just saying.
    trollst likes this.
  16. Deville1904
    Deville1904
    This is exactly my point. I am running other accesories and plan on getting it bagged so I really want to wire this properly. Anyone have suggestions on rewiring the ignition. Alot of the wiring in this cadi is OLD =P
  17. DougHH
    DougHH
    I've got a 3-wire from an early commodore in my '59 Belair. It's doing my head in. Car starts and runs fine, but when you go for a decent drive and you shut the car down it will not start again and needs to be jumped, which will also not happen for a while after stopping. I've also got no dash lights anymore and dim headlights after converting to Halogens which is driving me nuts.
    Multimeter is telling me its running 13 and a bit volts or there-abouts to the battery when cold.
    i've been through 3 alternators so far trying to rectify. one was confirmed stuffed by an auto electrician. last one i bought which should be good was a wreckers reco one.
    I've run the Big pole to the battery not sure which one was to the generator indicator bulb in the dash and the final to the relay/switch that runs to the horn.
    Can anyone please help?!?
  18. Ford-Man
    Ford-Man
    Be careful if you loop the one small wire over to the positive side...that wire is for the idiot light. If you go to any Advance Auto or Auto Zone...whatever McParts store you desire...they can show you the diagram out of the box. Pretty much all 3 wire alternators come with a wiring diagram to explain where the #1 and #2 wires go. On mine, one of em says to run to ignition switch, the other is to run in a loop to the idiot light...at least thats what the destructions told me.
  19. Aquaroscoe
    Aquaroscoe
    I wired mine last weekend as Enjenjo described. All wires go back to the fuse panel area. I added the lamp and diode (1n5408) if I recall correctly to a switched source.
    So to recap, big wire to junction block, #1 white wire to a diode (line [cathode] closest to alt) then a lamp then to a switched 12 vdc, and finally the #2 red wire to the fuseblock non-switched point.
    Flathead Dave likes this.
  20. Model A Vette
    Model A Vette
    Maybe this will help?
    Flathead Dave and snowroutes like this.
  21. Deville1904
    Deville1904
    Well now I just have to find the right alternator locally. Im looking for the 12si type by delco remy. I think its model number 7127. Anyone know if I can get this at autozone, pepboys, kragen? Anyone in san diego want to come over and help me wire it so I dont burn the cadillac down? Ha ha ^_^
  22. Model A Vette
    Model A Vette
    Yes, Autozone should have one.
    The answer to their question is: "75 Chevy Nova with A/C."
  23. Classic Boatworks
    Classic Boatworks
    Good info. I have a situation where at idle the alternator is putting out 13+ volts. When in gear and running drops as low as 8 volts. Scratch your head on that one! Had both alternator and battery checked. The wires from the alternator run to the starter. I have headers and getting to the starter is a real pain. My plan is to rewire #1 and #2. #1 I can pick up power at the positive side of the coil (right?). You mention #2 at the fuse box. Where on the fuse box will I attach the wire? 1985 GMC 350.
    Thanks,
    Dean
  24. the bulb has to be wired in series. so it's resistance creates a "break".
  25. gimpyshotrods
    gimpyshotrods
    Additionally, I put a diode in the wire from the indicator light. It stops the alternator from back feeding the harness, and keeping the ignition circuit hot, with the key off.
    Some guys go the extra mile and put a resistor in-parallel with the bulb, so the circuit still functions if the light bulb burns out, but I am too lazy to figure out which one, so I carry a spare bulb.
    snowroutes likes this.
  26. e1956v
    e1956v
    Alliance Vendor
    A diode in line with the #1 wire will stop the ignition run on as gimpyshotrods stated. If you have a alternator rebuild shop near you the WAI number is 46-1873 for a harness plug. [​IMG]
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
  27. e1956v
    e1956v
    Alliance Vendor
    3 amp axial should do. Sent you a message but I didn't realize you were down under.
  28. gimpyshotrods
    gimpyshotrods
    1N5408
    The thick stripe on the body goes on the side that wires to the alternator.
  29. If your ignition switch has an 'Accessory' position and terminal, connect the idiot light to that instead of the 'ignition' terminal. You won't need a diode...
    trollst likes this.
  30. gimpyshotrods
    gimpyshotrods
    And your alternator will be energized the whole time when you are making out with your girl at the overlook.
