Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-05-2012, 05:46 PM   #1
Hot Rod Dan
Grenade Inspector
Hot Rod Dan's Avatar
Default Camaro clip for 1950 Studebaker truck a bad idea?
I know some of you hate the Camaro clip/subframe idea for just about anything. But this is a budget project for my 15 year old son. He’s found a little Stude 2R truck and he wants to slam it.
He has very few bucks and is earning the money for everything, so a mustang II front suspension is not in the cards. I can possibly pick up a 2nd gen Camaro clip for $150 that looks like it was rebuilt at one time (upper ball joints have bolts rather than rivets). And I believe the track width is close to the 2R measurements.
So, has anyone done one of these mods and if so do you have any pictures or advise?
offline   Reply With Quote
Old 07-05-2012, 05:53 PM   #2
Tall Paul
Grenade Inspector
Location: Riverside, CA . . . Via Perth, Philly, and London
Default Re: Camaro clip for 1950 Studebaker truck a bad idea?
Not a camaro clip, but you could go jag IFS. Lotsa info on the net and here on the HAMB.
http://www.jalopyjournal.com/forum/s...t=jag+ifs+f100
Old 07-05-2012, 05:58 PM   #3
need louvers ?
Alliance Member
need louvers ?'s Avatar
I'm one the guys that would normally tell you not consider it, but in this case it would probably be ok. Track width should be pretty close, but if he really wants to drop it, it will drag tires all day long. The other concern I have is that those trucks have an awfully short nose to them out ahead of the front axle centerline. The steering box on the G.M. clip is pretty far forward - usually not a good combination. I would spend smone quality time with a tape measure before I went too far with this deal. At level best the steering box and core support will want to be in the same place though.
If it was mine I'd hit the U-pullit down the street and layout about 200.00 and go with a Jag XJ front end. Much easier to do and a bit narrower than the G.M.
__________________
HOT ROD CENTRAL LOUVER CO.
602.881.0175
louverguyquinn@yahoo.com
online   Reply With Quote
Old 07-05-2012, 06:06 PM   #4
skull
skull's Avatar
Lightbulb Re: Camaro clip for 1950 Studebaker truck a bad idea?
l got a 1977 nova sub-frame under my dodge truck and l love it.
it drives and handles really well, one thing that you may have to do is C-notch the rear frame rails to get the drive shaft angle correct. l had to do that in the truck to get a 2.5% down pinion angle and put in a camaro rear-end.
Later
__________________
dodge truck tribute build to my son.
http://www.jalopyjournal.com/forum/s....php?p=7118789
Old 07-05-2012, 08:48 PM   #5
Hot Rod Dan
Grenade Inspector
Good idea about using a Jag front suspension.
Anyone have pictures of a Studebaker truck with a Jag (or other than stock) front suspension?
Old 07-05-2012, 09:04 PM   #6
edweird
Alliance Member
edweird's Avatar
we put a 75 nova under this one. drives and rides great. the important thing is carefull measuring and good fabrication and welding skills. good luck.
__________________
see my artwork here www.pinheadlounge.com/edweird . will trade pinstriping or lettering for vintage gasser style[alum slots, cragars, torque thrust] rims. front [chevy bolt] or rear.[fordbolt]
Old 07-05-2012, 09:09 PM   #7
edweird
Alliance Member
edweird's Avatar
i think camaro and nova are the same width. the nova fits real good.
__________________
Old 07-05-2012, 09:18 PM   #8
BORRACHO13
Alliance Member
BORRACHO13's Avatar
if i had the choice i would go with the jag front end, i have not yet had a chance to do one myself, but the project seems easier and better looking than the clipping your car..
Old 07-05-2012, 10:27 PM   #9
aircap
aircap's Avatar
I know a guy who put the front and rear suspensions from a 80's Firebird under an R2 and said they fit with very few problems..... of course, he put a Ford motor under the hood.
Old 08-13-2012, 04:32 PM   #10
48bufordsled
Grenade Inspector
48bufordsled's Avatar
Got a Caprice subframe on my 2R5. Great, though you may need deeper backspaced rims.
Just put a Gen 2 camaro on the girlfriends M5.
Go do it...........................jag spares/rebuild parts are expensive
Paul
Click image for larger version
Old 08-13-2012, 06:49 PM   #11
40Standard
Old School HAMBer
I would do the Camaro clip, have one on a 56 Chevy truck and am real happy with it
Old 08-13-2012, 07:05 PM   #12
choptvan
Alliance Member
choptvan's Avatar
Get ahold of Dave Pareso. Back street Kustoms. Pretty sure he has one in his stude.
__________________
Hell Bounders CC Club President
Old 08-13-2012, 07:49 PM   #13
CharlieLed
Alliance Member
CharlieLed's Avatar
No Limit here in SoCal put out a video some time ago showing how they put a Camaro clip in a Chevy truck. Not a Stude but I am sure that the DVD would have a lot of good info that you could use...
http://www.nolimitparts.com/products.asp?dept=1207
__________________
The Stone Age did not end due to the lack of stones...
Old 09-01-2012, 11:53 AM   #14
kcstude
FNG
Here are a few pictures of my '55 Stude, which has the same frame as yours, with a '75 Camaro subframe.
Name:	Truck - motor.jpg
ID:	1729198   Click image for larger version
Name:	Truck - chasis.jpg
ID:	1729199   Click image for larger version
Old 09-01-2012, 12:10 PM   #15
Carl La Fong
Senior Member
Carl La Fong's Avatar
I put a Volare in mine. Notch the stock frame to match and weld it in
Old 09-01-2012, 12:43 PM   #16
PackardV8
Grenade Inspector
The Ford Aerostar front suspension is close to a bolt in on the C-cab. U-Pik yards are full of them for cheap, has disc brakes, decent steering, bolts to the stock frame with a couple of spacers and doesn't require any cutting or welding.
Check over on the SDC site or the Stude truck site for some photos.
jack vines
Old 09-01-2012, 10:45 PM   #17
Rocky Famoso
As per PackardV8 Ford Aerostar suggestion, here ya' go...
http://www.studebaker-info.org/tech/.../aerosusp.html
Old 09-01-2012, 11:04 PM   #18
temper_mental
Old School HAMBer
temper_mental's Avatar
Camaro clips are to wide especially if you slam the truck the tires will rube the fenders.
__________________
RIP SGT Tim SANCHEZ
3/5/74 3/14/07
Thaw
http://www.youtube.com/watch?v=n43G4K_lOxA
TX mile 151
Old 09-02-2012, 12:26 AM   #19
studebakerdave
Grenade Inspector
studebakerdave's Avatar
I have a 74 camero clip on my 53. It works great but if I had it to do over again I would save up for an after market mustang 2 or a fatman front suspension. When you cut the frame you lose all your body mounting points and brake pedal mounting points radiator I could go on and on. I have also seen one that was lowered with a droped axle and springs.I think the dropped axle would be the most tradional way Remember the old saying keep it simple stupid
ID:	1729789   Click image for larger version
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
