Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 04-11-2013, 11:48 PM   #1
carmuts
carmuts's Avatar
Default Autopulse Fuel Pumps
I dug out my Autopulse fuel pump to look it over some and possibly try to find Ethenol safe bellows and other parts for it. I did a search on the HAMB and the only place mentioned as possibly having the parts in an older post has discontinued making parts for them http://www.autoperformanceengineerin.../bel_pump.html . Anyone have any other ideas on where I might be able to get parts. Thanks Rod
Click image for larger version
offline   Reply With Quote
Old 04-11-2013, 11:58 PM   #2
MrModelT
Alliance Member
MrModelT's Avatar
Default
Best electric fuel pump ever made...imho. I have 4 of those ( 3 Model 500s and 1 Model 300) and have rebuilt them all, one of which is on my T roadster. I have not had any issues with mine yet ( been on since last July) and haven't seen any corrosion at all...though I do need to checj it again.
Gasket kits are available, but I have not found a source for new bellows. The early 300 and two of my 500s have copper bellows, but my newest 500 has rubber bellows....and you can imagine what that looks like, so I have been looking myself.
We don't have really high Ethanol fuel up here (5 or 10%) so it doesn't seem to cause much issues here. What % do you get at the pumps?
What model is your Autopulse?
Sent from Mr. ModelT's DROID device using the TJJ mobile app
__________________
"If a job is worth doing, it's worth doing right" - My Dad
1926 Ford Model T Roadster
My '26 Roadster build thread:http://www.jalopyjournal.com/forum/s...d.php?t=308741
online   Reply With Quote
Old 04-12-2013, 12:07 AM   #3
carmuts
carmuts's Avatar
Default Re: Autopulse Fuel Pumps
10% here, also have some without, but I wonder for how much longer. Thought this would be a good vintage piece for something I am working on although I am not sure which one to use it on. Not really nice enough looking to be under the hood of the delivery without alot of polishing. Might not be needed for awhile on the AV8 coupe as adding a 2 carb setup likely will come later so I can get by with a mechanical pump for awhile. Rod
Sponsored Links (Register now to hide all advertisements)
Old 04-12-2013, 04:30 AM   #4
cmyhtrod
Grenade Inspector
cmyhtrod's Avatar
How do you know what model they are? I have three that appear to have a factory type of manifold on both the suction & discharge sides. Any idea what they would be worth?
__________________
No one thinks about the water until the well runs dry
Old 04-12-2013, 08:58 AM   #5
carmuts
carmuts's Avatar
I did a search on e-bay last night and they are worth anywhere from $30-$400 depending on condition, model and voltage, so I really can't tell you much more. The Model number on mine is part of the aluminum casting. Rod
Old 04-12-2013, 08:59 AM   #6
MrModelT
Alliance Member
MrModelT's Avatar
Default
Quote:
The model number is usually cast on the center valve body, below the domed filter cover. Should have manufacturer's name and "Model 500 or 550" cast there as well. If it doesn't have a model number...it is most likely a older 300.
__________________
Old 04-12-2013, 09:03 AM   #7
MrModelT
Alliance Member
MrModelT's Avatar
Default
Quote:
We have mostly 10% and I have never had an issue here. Mine is under the hood and they look great polished or not. The Autopulse was the hot setup in the old days....all the old hot rod guys in the 40's and 50's used them because of their reliability and because they were built like aircraft components.
Sent from Mr.ModelT's DROID device using the TJJ mobile app
__________________
Old 04-12-2013, 12:17 PM   #8
MrModelT
Alliance Member
MrModelT's Avatar
Here are some comparisons between the early Model 300s and the 500s:
Valve Body casting text:
Model 300
Model 500
Inlet/Outlet Port bosses:
Model 300
Model 500
Points "vibrator" hinge and contact assembly:
Model 300
Model 500
Fuel Filter Screen Canister:
Model 500 (L) Model 300 (R)
Coil and Pump chassis cover:
Model 300 (L) Model 500 (R)
An Over all break down of the Autopulse (Model 500 shown)
Now there may be some exceptions to to these, but this is what I have observed and studied.
__________________
Old 02-02-2014, 08:32 PM   #9
blackrat40
blackrat40's Avatar
I owned a 1967 Piper Cherokee PA-180C private plane several years ago.
I was surprised to find an Autopulse electric back up fuel pump on it that it
was factory equipped with. It was identical to the one on my high school hot rod
that I built in the early 60's.
I would bet parts could be found through aircraft parts suppliers.
Be prepared to pay premium prices though. Everything aircraft must have FAA
certification to be installed on planes.
Try a Piper Aircraft repair facility for parts.
__________________
Time wounds all heels.
Old 02-03-2014, 06:51 PM   #10
blackrat40
blackrat40's Avatar
btt
__________________
Old 02-15-2014, 12:23 PM   #11
Va 33
FNG
Exotic classics.. Has rebuild kits
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
