Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#61 |
Alliance Member
Great project! Youre doing an amazing work on it, will follow on facebook
#62 |
FNG
Hi,
Here's a video to show you the atmosphere, and where we work. http://www.youtube.com/watch?feature...&v=PPvrUXwuRy0 We worked on the Wet Oil Pans We have expanded, so that the oil heats slower. ![]() ![]() ![]() ![]() ![]() ![]()
#63 |
Old School HAMBer
Nice work, Fellas'!
__________________
Chuck |
#64 |
Grenade Inspector
![]() Great build, now put on two very thick coats at the same time to make like a fire suit and see how you fit. Keep up the great work and make sure you look me up at the salt.
__________________
AKA Anthony Huntimer - Huntimer Photography Home of the World's Fastest Calendar |
#65 |
Grenade Inspector
Hey guys, if u can purchase Castrol B353 synthetic oil , it will sure help with heat problems , I used in race engines(wet and dry sump) with excellent results, these engines were run in 200-300 lap races, unforntunatly we can not purchase it here in Canada anymore.
__________________
If it's got tits or tires it may give you problems ! |
#66 |
Way cool project. Vive la Belgique.
Frenchy |
#67 |
Alliance Vendor
looks like a blast! let me know if you have any tech questions.
-rob (inspector) |
#68 |
very impressed, a great thread, subscribed............
__________________
captmullette, i started out with nothing, and I got most of it left....... in memory of my best friend "MULLETTE'
#69 |
Senior Member
I see a new movie produced called "The World's Fastest Belgian"
__________________
I live in Canada but my heart is in Detroit |
#70 |
Grenade Inspector
The Belgian Bonneville Bomber....
Can't wait to see it on the Salt! Awesome Work! Great shop pictures! Aloha Tommy
__________________
If everything seems under control, you're just not going fast enough Mario Andretti |
#71 |
Old School HAMBer
Looking good!
Its sometimes tough getting to Bville living in the states, good luck and stay the course.
__________________
Panel Beaters CC / Sidewinders |
#72 |
Grenade Inspector
Hey I wish I had seen this post a couple of weeks ago when I was in Belgium I would have loved to have made a visit. I should be building the body and painting the"City of Burbank" for the owner and to make it to the salt this year. (http://www.bonneville2012.com/). If you are near Hasselt in the next couple months check out the exhibition I am in at Z33 http://www.z33.be/en/projects/space-odyssey-20. Good luck with the project - very nice work
__________________
Smoke the Alligator! |
#73 |
Very nice job, IT'S WAY COOL!!
__________________
when the green light drops the bull shit stops ! |
#74 |
FNG
captmullette - 340HilbornDuster - plan9 - 5wcoupehunter - SwedeVedette - independentcustoms - der_brenner - and others: Thanks for your answers, it's always fun;-)
Typo41: We want to be there already, but we still have a lot of work, promi when will we are on the salt, we will. 66tintop: Thanks for the reference, it is noted. If you have any other advice, do not hesitate. Frenchy Dehoux: Merci pour le message ;-) So-Cal Speed Sacramento (Rob): thank you, we have some questions for the future, I send you it in private message. maccustom: Yes, we would appreciate to see you and introduce you to the project in real . Thank you for the links. If you come back, we will make sure to see you. Belgium is a tiny country. |
#75 |
Alliance Vendor
A coupe things here ....
-remember to do all your mocking-up and measuring while wearing a fire jacked (or two coats) and your helmet. The spacing between the top/ sides of the helmet is very important as well as the distance from the front of the helmet to the front of the cage (look in the book under Lateral Head Restraints) -is the bar that the top of the cage is resting on already welded in? i know it would be a lot of work, but if it is just tacked in place you may want to consider removing it and making the top of the cockpit tie directly into the center bars of the cage. (i hope that makes sense). the vertical bars are what's going to help of you go wrong-side-up and it is ideal if they are not split for a bar to go through. you would be better off with that horizontal bar being fish-mouthed around the vertical bars. it's not the end of the world either way and it's not something that would keep you from passing tech. just a suggestion. -lastly, keep your welding gaps in mind- especially with the fish mouths on the cage. you want them almost water-tight with a small bevel before you weld. if you're having to fill a gap, it's probably worth redoing. i don't mean to be a prick and i hope that helps! safety first!!! |
#76 | ||||
FNG
Quote:
Quote:
We received the roll cage tubes to the next weekend. Yes you are right, but the roll cage on the photo is not finished There will be a tube between the middle horizontal tube and the horizontal tube which is installed the roll cage driver. Because in case of pressure, the horizontal tube where the roll cage driver, he would not survive. Quote:
Quote:
Thanks Rob. |
#77 |
Alliance Vendor
any updates on this?
#78 |
Senior Member
Very nice!
#79 |
FNG
#80 |
Alliance Member
Great progress and awesome pics! Well done.
__________________
Mopar or no car GoldChainers CC President Holland Chapter Check out my build thread: http://www.jalopyjournal.com/forum/s...d.php?t=463453 |
| Thread Tools | |
| Display Modes | |
