Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 01-02-2013, 03:55 PM   #41
benreza
FNG
benreza's Avatar
Default Re: New Twist on a 1947 Ford COE Build
vey good job, welldone,
im after one of these truck any idea where to look one ???
offline   Reply With Quote
Old 01-02-2013, 05:54 PM   #42
TimeWarpF100
Grenade Inspector
TimeWarpF100's Avatar
Very neat project! I will be watching this one . . .
Old 01-02-2013, 06:28 PM   #43
RDP
Grenade Inspector
RDP's Avatar
I'm all in!!!
Old 01-03-2013, 08:06 AM   #44
sfm1951
Grenade Inspector
Cool Re: New Twist on a 1947 Ford COE Build
Subscribed. I would love to do a COE for a ramp truck for our body shop. You know just for the advertising. Yeah right I would drive the hell out of it , and haul everything on it but sailboat fuel.
__________________
Sometimes even a blind pig gets an acorn
Old 01-03-2013, 04:30 PM   #45
captainjunk#2
Old School HAMBer
wow that seems like some good service from charleys drop shop , project looks like its moving along pretty well
Old 01-12-2013, 02:13 PM   #46
Dough Boy
FNG
Dough Boy's Avatar
The week after New Year’s was a Hmmmm week. We needed to come up with a good structural plan to c notch the rear end. We had a couple of ideas that we thought might work, but we were concerned about if they would be strong enough to handle the weight. So we decided to get some help from Dave at One Up Offroad to give us some feedback on our plans. He was very helpful and we decided to scrap our idea and go with Dave's. It was definitely a more structurally better way to go. With our new plan in hand we headed to the shop to make a template for the parts that we were going to have CNC. The parts were going to take a week to make, so we moved on to engine placement. In that process we decided to box in the frame from the cab to the rear axle for better strength. We measured up the parts and made templates for the motor and transmission mounts and sent them to be CNC. We received our parts for the c notch on Thursday and we are back at it.
We need a 5" drop ii back
Parts that will make up the c notch. Made out of T1 steel for a little more strength.
Trail fit on the bench
All the parts to make our c notch
Fine tuning the fit
More test fitting. Will start to weld in on Monday.
Old 01-12-2013, 02:50 PM   #47
38Chevy454
Alliance Member
38Chevy454's Avatar
Nice progress. You might consider a different engine placement. I have a SBC on the stock mounts for a GM 1 ton pickup chassis, and even with my slightly larger 49 Ford COE cab, I have a pretty large engine cover inside the cab. I would look at putting the engine behind the cab, you can squeeze the front of the engine under the back of the cab. A BBC will be even larger than my SBC.
__________________
High Quality USA-made bear claw style latches CHEAP! Now have install kits also!
http://www.jalopyjournal.com/forum/s...d.php?t=620485
I used to have a handle on life......... then it broke
Old 01-12-2013, 03:33 PM   #48
ROBERT JAM
ROBERT JAM's Avatar
Keep us posted on the build! I think this will be a cool one
__________________
Hot rods are driven!! 32 ford (hemi power),28 roadster (flathead power)
Old 01-16-2013, 09:52 PM   #49
Dough Boy
FNG
Dough Boy's Avatar
C notches all welded in.
Next up is to box in the frame.
Old 01-16-2013, 10:15 PM   #50
chopd top
Alliance Member
chopd top's Avatar
OK, I'm in. This is going to be sweet!
__________________
"It's not what you look at that matters, it's what you see." ~ Henry David Thoreau
Old 01-16-2013, 10:27 PM   #51
4444Design
Grenade Inspector
interesting project
keep the pics comin'
__________________
www.4444-Chang-Jiang-Design.com
Old 01-17-2013, 10:00 PM   #52
RangeRansom
Niiiccceee!!!!
Old 01-17-2013, 11:07 PM   #53
RatPin
RatPin's Avatar
Wow subscribed! That looks like it will be very nice. I'd like to come down sometime and see it maybe.
If you need help, "will work for pizza"
Old 01-24-2013, 03:00 PM   #54
vonpahrkur
This is really cool!
__________________
i need: 39-40 lincoln frnt backing plate, 32 ford 3-windo door hinges,1940 Merc parts- frnt seat
Old 01-24-2013, 03:31 PM   #55
reallyrotten
Alliance Member
reallyrotten's Avatar
Awesome !
__________________
-Jake
1952 Crestline Victoria V8
The Build :
http://www.jalopyjournal.com/forum/s...d.php?t=755197
Old 01-24-2013, 04:22 PM   #56
Dough Boy
FNG
Dough Boy's Avatar
Starting to box in frame for better strength. Blasted the frame and gave a good coat of weldable primer to the inside frame for protection and for good solid welds.
Tack welded the parts in the frame and now ready to start building and placing the new motor mounts and cross member. We decided to design the mounts so that the motor and trany will be able to drop out the bottom of the frame. This will give us more flexibility when building the box on top. Chris laid out the new cross member on his table and pieced the parts together for a prefect fit.
The parts test fitted and ready to be welded.
All welded up and ready to place the new cross member in the fame.
The cross member is temporary tack welded in for fit. It will be bolted too the frame on the side and bottom.
Used the same techniques on the transmission cross member.
Motor and transmission in new resting place and all leveled out.
Old 01-24-2013, 08:27 PM   #57
kscarguy
kscarguy's Avatar
Nice job on the engine mounts. Makes me want to redo mine.
Old 01-25-2013, 04:28 AM   #58
flatspin49
FNG
Am looking for some info on a 42 - 47 Ford Truck steering lock. I was a bit rough with one today and snapped the chrome piece of and have moved it halfway between on and off. Does anyone know where I can buy another one? Ta.
Old 01-25-2013, 05:17 AM   #59
IowaMercMan
Alliance Member
IowaMercMan's Avatar
Default
Cool.
Walt
__________________
Walt
Outsiders C.C.
Old 01-25-2013, 06:38 AM   #60
39Tudor
FNG
Very nice work.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
