Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-18-2007, 09:22 PM   #1
Lugnutz
Newbie
Lugnutz's Avatar
Default Crown Vic Front Clip in a 48 Ford F1 Pickup?
I'm redoing a 48 Ford F1 Pickup, and I have a chance to buy an 84 Ford Crown Victoria for a good price. It's a 302 and automatic. I'm thinking I might possibly be able to move the entire drivetrain over to my F1 (and replace the fuel injection with carbureutor of course). Here's my question. If I don't plan to drop the truck really low, could I possibly use the front clip and a portion of the frame from the Crown Vic, and weld it up to the F1 frame? I think the tracking is about right, but has anyone here done this before? Does anyone have any input as to what the good and bad to this might be? Is this just a stupid idea, or will it work?
__________________
Gimme two bucks worth of regular and keep your greasy hands off my dipstick.
offline   Reply With Quote
Old 07-19-2007, 05:59 PM   #2
Lugnutz
Newbie
Lugnutz's Avatar
Default Re: Crown Vic Front Clip in a 48 Ford F1 Pickup?
Ok, I see that 30 people have viewed my post here, but nobody has commented either positively nor negatively about this idea. Surely someone has done this before, or someone at least has a comment? I see alot about Camaro or Firebird front clip swaps, but why wouldn't this work?
__________________
Old 07-19-2007, 06:05 PM   #3
Crestliner
Old School HAMBer
Crestliner's Avatar
I would say the first thing is to check the width. A lot ot subframes are to wide and look like s--t.
__________________
My dad always said, A MAN IS NO BETTER THAN HIS WORD!!
F/S 67-68 BUICK CONV. BLACK TOP & 1/4 PATCH PANELS
Sponsored Links (Register now to hide all advertisements)
Old 07-19-2007, 06:21 PM   #4
Notorious
Grenade Inspector
Notorious's Avatar
That's the trouble with Fords. They never used anything except their crappy unibodies in smaller cars. The only later car frame which might be a tad narrower would be the '72 and up Torino, (big) Cougars, LTDII, etc. Before '72, even the Torinos were unibody. I would certainly have to think that the later full size platform is going to be too wide for your truck. You might get away with it with wheels that are nearly completely offset inward, but I don't think you want that. There are some oil pan set-ups that would allow your engine to work well with a GM clip, if that later 302's pan is not compatible.
__________________
Some people are like slinkies. They don't really have a purpose, but they still bring a smile to your face when you push them down the steps.....
Old 07-19-2007, 06:42 PM   #5
pimpin paint
Old School HAMBer
pimpin paint's Avatar
Hey,
first off- Are ya sure about the fuel injection in '84?
Measure the track first, center of tire to center of tire.
Measure and compare the frame rails of the Crown Vic to the
pick up. You may have to step cut the Crown vic cross member
to get it to fit. How much wider is the Crown Vic than the Pick up?
maybe a pick up on a Crown Vic. frame?
Swankey Devils c.C.
Old 07-19-2007, 06:52 PM   #6
Henry Floored
Senior Member
Henry Floored's Avatar
I would'nt do it. I'd look into an Aerostar front end for that truck. I helped a guy mount one once in a `50 F-1 and it worked well. If memory serves me correctly the `50 F-1 frame sat right down where the Aerostar frame rails once were. Did I mention that the whole assembly unbolts from the Aerostar. The biggest hurdles were mounting the upper A- frames on top of the F-1 framerails, and the Aerostar rack points up at about 60 degrees instead of back at 45 dgrees or so. No big deal really to modify the rack mount. IMO this would be a way better situation than cutting frame rails.
Old 07-19-2007, 07:13 PM   #7
George
Old School HAMBer
George's Avatar
I believe they had carbs through '85.
__________________
Confucious say Tennis elbow better than Tennis balls
Old 07-19-2007, 08:18 PM   #8
spare parts
FNG
Lugnutz,Go to www.ford-trucks.com do a search on '48/'60 front suspension alternatives and chech out Part 4. It expains the crown vic swap.
Old 07-21-2007, 12:20 PM   #9
Lugnutz
Newbie
Lugnutz's Avatar
Thanks guys. I gained alot of useful info here. I'm not sure about the fuel injection. That's just what the guy who owns it told me, and I've never looked under the hood. Would be nice if it is carb fed. The ford-trucks site is really chocked full of good info. Thanks for that SpareParts. I never considered the Aerostar frontend swap, so I'll keep that in mind. I first thought I'd graft the F1 frame to a 1st or 2nd generation Camaro front-end, and I'm still thinking that may be the best way to go.
__________________
Old 07-21-2007, 01:39 PM   #10
JeffB2
Old School HAMBer
JeffB2's Avatar
Wrong,1984 & 1985 had TBI's they did have the same baseplate on the intake as a 2bbl .I have a '84 302 & AOD in my '54 Customline.
Old 07-21-2007, 02:01 PM   #11
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
I have seen it done with a full sized Ford front, but the fellow said never again. I have a 52 F1 that I plan to build soon, I want to use a front from an Aerostar van. The width is right, it bolts on with four bolts, but to get the truck low enough, it may need to be Zeed. It has 10 1/4 inch discs, power rack, huge sway bar, all in one.
Old 07-21-2007, 08:36 PM   #12
Flat Ernie
Tech Editor
Flat Ernie's Avatar
The front track width on the early trucks is quit narrow - something on the order of 57" or so...check the track width carefully.
Yes, early '80s Ford luxo-barges were TBI...
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch!
T5 Tech
Old 07-21-2007, 09:09 PM   #13
McKee
Senior Member
McKee's Avatar
Too Wide!
Old 07-22-2007, 11:03 AM   #14
38Chevy454
Alliance Member
38Chevy454's Avatar
One word for your front suspension: Jaguar
The Jag front clip is almost a bolt-in, and you will be down in the weeds without Z-ing the frame. Most 70-80's Jags are nearly free as the engines cost too much to mess with when things go bad, plus the bodies and electrical problems. The front suspension is a good design and is essentially self-contained unit that you can unbolt from the donor car. Oh yeah, they also have 5 on 4.75 GM bolt pattern for the wheels.
__________________
High Quality USA-made bear claw style latches CHEAP! Now have install kits also!
http://www.jalopyjournal.com/forum/s...d.php?t=620485
Purchase directly here: www.hotrodlatches.com
Old 12-23-2012, 01:57 PM   #15
EJ
FNG
What year of aerostar van do he use for the front end.
Old 12-23-2012, 02:31 PM   #16
n.z.rodder
n.z.rodder's Avatar
Why not use the original front end THAT"S what would be used in a pre-64 Hot Rod. With the parts available, new and used, it IS the only option 'round these parts.
Scotty
__________________
Don't get on it if you can't stay in it!
Old 12-23-2012, 02:43 PM   #17
gasmanm01
Alliance Member
gasmanm01's Avatar
i used a 3" dropped axle from sids, 2" reversed eye dropped monoleaf springs, original drum brakes and original sterring with a small block chevy and 5-speed. woks very well, over 5000 miles since june. i dont im=nderstand why any one would want to use oddball stuff that few have tryed. the jaguar is a good set up, the rest i have seen done and they dont look right, tires hit etc. mine is as low as i wanted it and can barley get a floor jack under it, but rides and handles very well, just my 2 cents.
Old 12-23-2012, 03:16 PM   #18
CTFuzz
Old School HAMBer
CTFuzz's Avatar
Location: the smallest town in the smallest county in the smallest state
CV front clips only work on the "slick 60'S" trucks.........unless you want to do this............http://www.jalopyjournal.com/forum/s...d.php?t=762276
This is the late model ALUMINUM clip and it is a "bolt in"(more or less)
__________________
http://jalopytimes.blogspot.com/
Pictures of Great New England Cars
Old 12-23-2012, 03:44 PM   #19
Unkl Ian
Old School HAMBer
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
Why is it people can afford old cars, but not a tape measure ?
__________________
Updated:
FlyingEyeballs.net
Old 12-23-2012, 03:52 PM   #20
adam401
Alliance Member
adam401's Avatar
Quote:
Also why do people post about stupid modern conversions on a traditional hot rod forum? So many unanswered questions.
__________________
Sin Alley Saints CC
dropping axles, cutting cars. Check out my albums to feel better about yourself
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
