Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-09-2012, 12:33 AM   #21
BadassBadger
Grenade Inspector
BadassBadger's Avatar
Default Re: Saginaw 4 speed help
heres what you do. smack with a hammer a few times then put in a muncie!
kid i kid i have a sag 4 speed as well
__________________
PONIES.....taking over and confusing the hell out of manly men since 10/2010
offline   Reply With Quote
Old 10-09-2012, 06:29 AM   #22
LDO
FNG
Quote:
Originally Posted by Johnny Gee View Post
There it is, the 1 to 1 syncro (or 4th) is not seated correctly. Meaning it got rotated slightly and causing a separation making it bind and causing it to act like it's in 4th gear or input and output are ingaged when there not. The cones are seated tight together right now.
Question, you removed the tail housing while it was in the truck? Because the whole main shaft is generally removed with the tail housing as a unit, then getting to the C- clip is easy.
The manual i used didnt say the tail shaft came out. I was told to rotate the housing until the window was visible then remove the c clip, when i did that i was able to remove the housing no prob.
So do i need to reove the housing again and should it come out with the mainshaft and all those gears?
Does it just come out as a unit or is there a retention device of some kind?
Old 10-09-2012, 10:32 AM   #23
Johnny Gee
Old School HAMBer
Johnny Gee's Avatar
Location: 2.7 miles East of the Broiler on SR42 Downey, Ca
Quote:
See your not so bad off as you may think. I never tried that approach.
No need to remove tail housing again. Just loosen the bolts to the tail housing so as to let it be pulled back a bit, then rotate the most forward syncro (4th gear) till you feel it settle in to the tabs. Then snug up the tail with 2 bolts only and see if all is back in place. This should do it. By the way, do you find it has a lot of drag or harder that normal turn at the yoke at this time when able to turn with the clutch.
__________________
Mussels with French Fries and Mayonaise
Old 10-09-2012, 10:37 AM   #24
Johnny Gee
Old School HAMBer
Johnny Gee's Avatar
Funny, hammers don't discriminate. Muncie will do this same thing if not reassembled correctly. So what's your point
__________________
Old 10-09-2012, 01:36 PM   #25
LDO
FNG
Johnny, i realized (you can't see in the pics) but one of the synchros was up against the gear and would lock things up, it was wedged pretty good. Screwdriver did the trick and everything is good now. Filling it with fluid and going to button her up.
By the way, I have a drive shaft that is tapered on both ends, does the pinion go on the longer taper? Makes sense to me but i'm a little loopy at the moment since I've been under my truck since Saturday!
Old 10-09-2012, 03:06 PM   #26
Johnny Gee
Old School HAMBer
Johnny Gee's Avatar
Good deal, just about the same affect as to I was referring to. Which syncro by the way? As for as the drive shaft, sorry no answer. 1, I don't know that truck, and 2, I'm not a mechanic by trade. But someone will chime in I'm sure on the drive shaft.
__________________
Old 10-09-2012, 06:17 PM   #27
old soul
Senior Member
old soul's Avatar
oh boy. If you cant get it pull the tranny out.
__________________
SORRY FOR THE SPELLING IM A GREASER NOT A JOCK!!!!!!!!
online   Reply With Quote
Old 10-09-2012, 08:29 PM   #28
LDO
FNG
Thanks to Johnny and everyone else that took the time to reply and try to help get me back on the road.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
