Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 01-29-2012, 11:19 AM   #21
302aod
Grenade Inspector
Default Re: My 64 F100 build...resto-mod...begins...
The 87 frame is twin I-beam, sway bars front and rear. Haven't seen this frame swap before and I now see why. Every dimension on the 87 frame is different than the 64. I'm not giving up, just more thinking and more work.
offline   Reply With Quote
Old 03-24-2012, 11:32 PM   #22
Harpo
FNG
Harpo's Avatar
i actually found about a 61 and am in the process of removing it and re-boarding it
where in alabama are you located?
thanks
Ben
__________________
building my 65 just like Shelby would have?
Old 09-08-2012, 05:54 AM   #23
Harpo
FNG
Harpo's Avatar
update: and slow progress.
Yesterday I went by the media blaster to review the bed box (floor removed) and the hood. Pictures to follow.
thanks
__________________
Old 09-08-2012, 06:46 AM   #24
fordsbyjay
Grenade Inspector
fordsbyjay's Avatar
You can always use the front end from a 03+ crown victoria. On the later models the cross member unbolts from the car and happens to be the right width for an F150. It lowers the truck some and rides like a dream. Check it out over at FTE. There is a bunch of threads over there on the topic. It is pretty popular with the 70's models but your truck frame should be the same.
http://www.ford-trucks.com/forums/10...questions.html
Here is another option one using a Marauder frame which should be the same as the crown victoria.
http://www.ford-trucks.com/forums/11...r-chassis.html
__________________
Guide to posting pictures.
Old 09-09-2012, 12:05 AM   #25
Harpo
FNG
Harpo's Avatar
After media blast and epoxy primer, i know its not perfect, however it is now Rust Free
__________________
Old 09-13-2012, 11:36 AM   #26
Harpo
FNG
Harpo's Avatar
picking up a new spool of .023 mild steel wire today, so i should have some pieces welded up and pics on here pretty soon.
__________________
Old 09-13-2012, 08:45 PM   #27
Chris F100
Grenade Inspector
Heres how I did the hood of my 62 (same as yours I believe) with the same leading edge rust out.
After cutting out the rot I used 1/8 rod to form the leading edge. Welded patches to it and then ground it down. Good luck with yours...
Click image for larger version
ID:	1739246   Click image for larger version
ID:	1739247   Click image for larger version
ID:	1739249   Click image for larger version
ID:	1739250   Click image for larger version
Old 10-05-2012, 12:01 AM   #28
Harpo
FNG
Harpo's Avatar
that is some good looking work. Mine doesnt have to be perfect...i like your idea of the rod, i am a long ways away from worrying about the hood at this point, but I definetly will keep your work in the back of my mind, so when i do get to that point, I'll have an idea where to start. before you posted this, I had No idea how to make it look right....
thanks
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
