Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 08-21-2012, 07:30 PM   #1
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Default Dual carbs: Stromberg WW or Rochester 2G?
I have access to both types, and would like pros and cons of running a pair of them on a Cadillac flathead with an Edmunds dual carb manifold. Is one easier to tune than the other, any common problems with either, etc. Looking for recommendations on which might be the better carbs to use in a pair. Thanks!
offline   Reply With Quote
Old 08-21-2012, 11:23 PM   #2
rat bastad
Old School HAMBer
rat bastad's Avatar
Default Re: Dual carbs: Stromberg WW or Rochester 2G?
Here ya go...
http://www.jalopyjournal.com/forum/s...ad.php?t=96174
Rat
__________________
"IF IT WAS'NT FOR BAD LUCK I WOULD'NT HAVE ANY LUCK AT ALL"
Old 08-22-2012, 07:42 AM   #3
carbking
Senior Member
carbking's Avatar
Both the Stromberg WW and Rochester 2-G series are excellent carburetors.
Both share one common issue and that is the local unavailability of tuning parts. Tuning parts ARE available mail order.
The Rochester carbs have fewer tuning parts available (idle jets, most air bleeds, emulsion tubes, etc. are fixed and must be drilled). These parts for the most part are removable on the Strombergs.
The Strombergs have one major design problem that is easily repairable. Since Stromberg used aluminum throttle bodies, as the aluminum oxidizes over time, the aluminum oxide tends to wear the throttle shafts. Any competant rebuilder will install bronze bushings in the throttle body (and a new throttle shaft if necessary) and this permanently solves the problem.
Early Strombergs also require a special jet wrench (available mail order) to remove/replace main metering jets.
Remember when acquiring a "set" of either that there are hundreds of different of each type, used for many different displacement engines. Do your homework, determine what carburetors will work best for your application, and acquire a matched set.
Jon.
__________________
Good carburetion is fuelish hot air!
The Carburetor Shop of Missouri 573-392-7378 (9-4 M-Tues CT)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
