Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
has anyone done it? How hard is it? What did you do for reverse?
Any help would be appreciated. I think column shifting is cool/old school! Thanks, Paul
__________________
NashRodMan I can't give you brains, but I can give you a diploma. - The Wizard of Oz |
#2 |
They say anything is possible, but that would be a tough one. Have you looked at the difference between a top loader and side loader?
__________________
Gene |
#3 |
Alliance Member
Why?
#4 |
Alliance Member
"""""""""""""""""""" WHAT DID YOU ASK ???
#5 |
Senior Member
Location: The Garage with the lights on in Richland Center Wisconsin
When I was a kid, ( early 60s ) the first thing we used to do was to get the 3 speed shifter on the floor, then later on if we could afford it we bought a 4 speed and a Hurst shifter. why would you want to try to put a 5 speed on the column????
![]() I'm just asking.
__________________
Tomorrow is promised to no one |
#6 | |
Quote:
__________________
#7 |
Senior Member
NO! Column shift can only operate 3 speeds. The mechanism is a lever that moves to the left, up&down, then right, up&down. 4 positions only, 3 forward gears 1 reverse.
You could make that shifter operate a Automatic trans. |
#8 |
Thanks MC.
__________________
#9 |
Senior Member
Get a phillips screwdriver & take off the 4 screws on that little shifter box on the column under the hood & see how it works, it's very simple. Grease it & put the cap back on.
#10 |
Senior Member
Easilly? Not even close.
Can be done? Yep, lot of time and engineering, and most anything CAN be done.
__________________
Some of you guys are so tight with your money, I bet you can stretch a penny to wire your car. |
#11 |
Old School HAMBer
You could shift a 4spd with a column shifter, with a separate stealth shifter on the floor or an electric solenoid for reverse, but a 5spd...whoa.
__________________
Garage Sale Vintage Parts Priced To Sell! http://www.jalopyjournal.com/forum/s...d.php?t=801976 |
#12 |
Grenade Inspector
I believe there were some british cars with a 4spd column shift, can't remember which, any old brits out there.? Or maybe it was peugeot, had one a very long time ago
__________________
"Whither goest thou, America, in thy shiny car in the night?" Jack Kerouac |
#13 | |
Alliance Member
Quote:
I believe it was also a common practice in some foreign cars. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot '54 Ranch Wagon build photos |
#14 |
Alliance Member
There's a few threads on here about that.
One of them is about developing such a shifter. The problem is having so many gates in the column. The next problem is not having any external shift levers. As far as gates go, With a 3 speed there's only 2, 4 speed has 3, 5speed can have 3 or 4. That's a lot of crap to stuff into a column. Another poster stated that a foreign manufacturer had done this, search them out. Top loader means the gears load from the top. It has nothing to do with the shifter, its location, method of operation, or mounting. Column shifting ain't cool, its ancient OEM not old school.
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#15 |
Senior Member
#16 | |
Senior Member
Quote:
__________________
"I sinned, I used some ford stuff but havent they used our engines for years !!" nailhead terry |
#17 |
Senior Member
That's what I thought, I like big bad hot rods too, until I drove my 53 Panel. It's kind of cool, both your hands are out there Big in front of you, its kind of tough feeling, kind of like those dumb ape hangers on a Harley. Kind of like a brawler.
#18 |
Senior Member
I kind of miss my 59 Ranchero with 3 on the tree.
__________________
#19 |
Old School HAMBer
I had a 1965 Datsun truck with a 4 speed column shift, I am fairly certain it was a "top shift" type trans, though I just drove it and never really had to work on it so I could be wrong on that
5-speed column shift... that would be some engineering marvel. ... as for why.... the other day there was a stock looking 41 Pontiac sedan across the street from me at the auto repair shop, when I looked inside there was a big ol 5 speed shifter coming out from the floor. would have been more cool on the column. big ol' stock looking 4 door sedan... don't know what motor was in it but it did have dual exhaust.
__________________
"everytime someone posts about an LS motor on the HAMB a vintage motor throws a rod through the pan" |
#20 |
Alliance Member
41 Packard was a column shifted toploader arrangement...but still a 3 speed.
I would look at using a column shifted 3 speed along with a seperate aftermarket overdrive unit... Neal
__________________
"We have had years to perfect our interpretation of the traditional rod..." bobbleed |
| Thread Tools | |
| Display Modes | |
