Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
Who makes the smallest 12 volt battery that will provide the cranking amps and life needed for multiple engine turn overs and starts without causing problems ?
Im looking for a very small battery ( packaging issues- where to put a battery ) for my Y Block powered 26 roadster pickup.I want to be able to start the engine and make repeated starts after short distances, without turning the key to find a battery that won't turn the engine over
#2 |
Grenade Inspector
I used a 2003 Honda Civic battery from Advance Auto rated at 500 cold crank amps. its pretty small.
Here is a link to battery sizes based on BCI battery group number. The Civic battery is group 51. http://www.rtpnet.org/teaa/bcigroup.html A 2003 Toyota Rav4 battery is slightly bigger but has roughly 640 cold crank amps. Its a group number 35. Bryan
__________________
My 30 Model A Sedan Progress album: http://www.jalopyjournal.com/forum/a...p?albumid=8002 Last edited by brpowel4; 07-21-2012 at 11:04 PM. |
#3 |
I'm using an Odyssey PC680 to run my 318 poly in the 32-5w. It seems to do the job just fine and ct1932 ford on here is using one to crank the 21 studder in his revamped 32 roadster. You could PM him and ask him if it's doing the job OK. I don't think you would get anything smaller that would do the job.
Dimensions are 7.15" long, 3" wide and 6.65" high You can check them out at odysseybattery.com BTW mines in the trunk and I'm only using an early birdcage Chrysler alternator which has a WHOPPING 35amps output. |
#4 |
Location: Gardner Kansas - Transplant...Orgnially Hays America
optima 75/25. http://www.optimabatteries.com/optim...dtop/specs.php
i love these batteries. wont run nothin else. |
#5 |
Grenade Inspector
I use a group 51 battery you can get them with positive at right or left
__________________
BRUCE'S ROD SHOP SPRING,TEXAS 281 376-5932 "AS FOR ME AND MY HOUSE,WE WILL SERVE THE LORD!"
#6 | |
Alliance Member
Quote:
Putting one in another 29 I'm building for a customer right now. http://www.odysseybattery.com/autospecs.html
__________________
HOT RODDING - It used to be about the cars, now it's just a freakin Fashion Show ![]() |
#7 |
Senior Member
Another Odyssey fan, lays on floor under front seat, been there for years now and had no issues whatsoever. I use a trickle charger to keep it topped up as not a daily driver.
#8 | |
Alliance Member
Quote:
__________________
VULTURES Australia Your concerns about whether what you are about to do is going to end well, are well founded. |
#9 | |
Senior Member
Quote:
A regular one will not work The charger is as much as the battery
__________________
"Look out boys! I gotta license to fly!" |
#10 |
Alliance Member
Check again. 370cca
__________________
#11 |
Senior Member
I also have one of these in a Honda Insight. tiny battery, works great.
__________________
I Ain't Mad At Cha. |
#12 | |
Alliance Member
Quote:
If they required a "special" charger, then they would also require a "special" alternator on the vehicles they are installed in. |
#13 |
Alliance Member
Odyssey battery would be the first place I look.
Amazing how much power is in their small packages.
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#14 | |
Senior Member
Quote:
__________________
#15 |
Alliance Member
I may have to look into one of those Odyssey batteries, we were just talking about a small bat for my Tudor.
__________________
Y-Block Powered Model A Tudor project http://www.jalopyjournal.com/forum/s...d.php?t=667198 "it looks just like a Tellafunkin U-47" http://yblockguy.com/ |
#16 |
Senior Member
Satisfied Odyssey PC680 owner here as well. I have it mounted up under the dash.
__________________
"Who's your Unkledaddy?" |
#17 |
Old School HAMBer
I used a 12v tractor battery (Interstate) in my flatty powered bucket.
__________________
'Armin Tamzarian's reign of terror is over!' -Superintendent Chalmers |
#18 |
Alliance Member
Thanks guys it looks like the Odyssey PC680 will be the one. It really is the smallest and I was concerned in its ability.
Good to hear that it has been used sucessfully in applications like mine.
#19 | ||
Quote:
Quote:
got it right. my regular charger from the big W works fine. just make sure you do the slow charge. that seems to work better. |
#20 |
Old School HAMBer
I'm another fan of the PC680 battery. When I built my 23 there was no room for a regular battery so I called Odyssey and spoke to the owner of the company. I told him I was concerned that a small battery like that wouldn't start the 350 Chevy in my rod. He said he has a blown BBC in his and it works great. I bought one and he was right, even after sitting for weeks it would crank over like it was fully charged.
And no, you don't need a special charger for any of these batteries, a regular smart charger will work fine. Don |
| Thread Tools | |
| Display Modes | |
