Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > Events > H.A.M.B. Drag Nationals > HA/GR
Reply
Thread Tools Display Modes
Old 06-25-2012, 08:09 PM   #1
ThingyM
Default Midnight Madness Change over
Well, Now that I have my Altered all ready to go..Now its time for my HA/GR to become an SDRA car..The chassis is stripped of everything and going to set in a mock up 300" Ford and C4 trans.So I can build mounts and cross members as necessary. I found a 9" ford rearend that was set up for a Pinto So I think I'll use that as it has the same tread width as my S10 rear does. Also thinking something in the ratio of 3.78 gears for the rear. I'm gonna see how fast I can complete this change..But like everyone says. "The hurrier I go, The behinder I get"....
offline   Reply With Quote
Old 06-25-2012, 09:27 PM   #2
Old28
Old28's Avatar
Default Re: Midnight Madness Change over
Great news Dick, with your shop & tools my money is on it being ready in time for the next ANRA race end of August.
3.78 are the same gears I have in my 8.8 rear end.
I had Papa Joe take a tech look at the car and he went over it with a fine tooth comb. Only a few small items. I did have to relocate fuel regulator as it was to close to the flexplate cover (most clear 6" or more). I have to re-weld a couple of places were it was ground. I new they would say something about that, no biggie.
Sure will be fun to have a second SDRA car to race and maybe we can talk gary with his flathead/C4 to put on a set of 6" radials for Saturday rounds. I have not heard from Skip Pipes in a month or so, I will send him a PM and see where he is at on his HA/GR to SDRA change over.
__________________
Build It - Race It - Have Fun
"I'd Rather Be Racing"
Old 06-25-2012, 11:23 PM   #3
Old6rodder
Alliance Member
Old6rodder's Avatar
Excellent!
Great news, Dick. Hell, the brakes, steering, etc, etc, are all already "road" tested, should be a lot of small things already done that usually slow a build down.
__________________
Dick, 225% crazy
Cassi, El Toad & Flyin' Brick II
I've raced.
I've driven normally.
I prefer racing.
Old 06-26-2012, 02:07 PM   #4
ThingyM
Yep.. Going to use the front end, Steering and components. Master cylinder and brake handle, Etc. Even the gas tank and necessary lines..But the chassis does have to get a good Rustoleom paint job......
Old 06-27-2012, 12:34 AM   #5
Old28
Old28's Avatar
PICTURES / PICTURES / PICTURES
Not much into reading !!!!!!!!!
Summer Nationals are gust around the corner.
__________________
Old 06-27-2012, 07:58 AM   #6
bobw
Senior Member
It's great to see you back in the game.
Old 07-06-2012, 05:56 PM   #7
Old28
Old28's Avatar
Yo Dick, any think happening on the car??????????????
August race is just around the corner.
If I get my seat back from the upholstery guy, he is doing a black pleated insert with some foam for my big a--, I am ready to make a street run. I hope to make a Friday T&T later this month.
__________________
Old 07-06-2012, 08:00 PM   #8
ThingyM
Not to much, As we have been busier than a cat covering poop at the shop.. I do have the engine on the stand and starting to take it apart. And the chassis is going to be blasted and powdercoated, Then I can put some of the things back on it.. They said that the motor has a "Clunk" in it so I will have to dig into it and "Fix It" first...Can't make ANRA with it, But I will be there with the Fiat...
Old 07-06-2012, 08:41 PM   #9
Old28
Old28's Avatar
Powder coated, nice,nice,nice.
What did you find out about the Fiat stuff?
I got my carbs set pretty good, had an oil leak on a side cover and I am getting a little from a seam on the pan section that was added. I am going to clear the area and JB Weld it. I converted the points setup to a Pertronix unit and tested it today, looks like it will work fine.
It has been 99-100 for the past few days and I have ran the motor in the garage for 5 min or more with the water pump & electric fan on and it has not got over 195 deg as I play with the RPM's. I will tell you that this little 194 sounds nice with just a cam in it.
__________________
Old 07-07-2012, 12:54 PM   #10
ThingyM
The springs were in the wrong popits, The 20# spring was on the main and the 2# spring was on the return,,, So there ya go.. we all overlooked that part..OK now.....
Old 07-07-2012, 03:22 PM   #11
Old28
Old28's Avatar
Well Dick, that just shows what to many hands in the pot can do.
Glad it was a simple fix and that the motor oiling system changes worked out. We will see you in August, should be about the same temp as we had in June, HOT-HOT-HOT.
They call for 99-108 temp for the next 10 days, Dixie, Me & Dog are going over to Morro Bay on Thur for a few days of 65 deg fun.
__________________
Old 07-17-2012, 11:16 PM   #12
ThingyM
Got the block torn down.. Everything looks REALLY GOOD.. The bearings are like new.. Can't figure what the Clunk sound might have been Maybe just a bad lifter.. The crank is going to Henry Velasco to get checked out and polished. Checking on some better rods and pistons. George over at Clay Smith is going to grind me a new cam. The one thing that bothers me is that the rockers are pedestal mounted.. Those new dudes cost alot of $$$$$ Will get back with it tomarrow...
Old 07-18-2012, 04:43 PM   #13
Old28
Old28's Avatar
Found this on the web about removing the pedistal mount, cutting the tower bosses, putting in Chevy studs and running SBC or BBC roller rockers depending on cam spec. Looks the same as you did on the 194 head.
Glad the bottom end looks nice. Are you going to build fab intake or use one 4bl aftermarket intake?
Nice to see your making progress on the modification.
Rocker swap on 300 six
by 300 I6 » Thu Aug 18, 2011 12:26 am
I would like to know what all I need to put the chevy I6 1.7 rockers to ger more lift with stock cam on my 85 300 I6?
300 I6Posts: 5Joined: Wed Aug 17, 2011 11:27 pmTop
Re: Rocker swap on 300 six
by THE FRENCHTOWN FLYER » Thu Aug 18, 2011 12:42 am
The existing studs need to be removed.
The rocker arm bosses need to be milled down to allow room for the screw-in stud hex.
The correct rocker arm geometry should be calculated based on the cam you are using.
That will give you the correct pushrod length. If you are lucky the stock pushrods (or dealer available optional extra long ones) will be close enough to work. Otherwise, custom ones are required.
You may be able to short cut these directions - for example, use the existing pressed-in studs if your engine is so equipped - but taking the time to do it as I outlined will make for a more robust system.
FORD 300 INLINE SIX - THE BEST KEPT SECRET IN DRAG RACING
THE FRENCHTOWN FLYERVIP MemberPosts: 3783Joined: Sat Nov 09, 2002 10:25 pmLocation: FRENCHTOWNTop
by 300 I6 » Thu Aug 18, 2011 10:41 am
Is there a easier way n cheaper cuz I've been reading a little on the rocker swap with using the chevy rockers out of a inline 6. I don't no if my 300 is pedestal mount rockers or studs it's a 85 motor but looks like it would be easier just to put a cam in it.
by StrangeRanger » Thu Aug 18, 2011 11:11 am
Pedestal mount rockers are held in place by a bolt and have a round pushrod hole; stud mount rockers are held in place by a locknut and have a narrow pushrod slot.
If you have pedestal rockers, you will need to add pushrod guide plates in order to do the C***y rocker swap. The stud mount rockers with the narrow pushrod slots do not require the addition of guide plates.
Whether you swap in an aftermarket cam or merely change to high lift rockers, you should put in a set of valve springs sized for the increased lift. If you have a phenolic timing gear set it is also an extremely good idea to swap out to a metal one when you do either the cam or the rocker swap.
FWIW specs on the stock cam are 400" lift at 268°advertised duration 192°duration at .050" and 112°LCA
The change to the C***y rockers increases the lift to .435" and increases the duration at .050" by a very small amount.
The closest aftermarket cam is probably Crower 19211
.426" at 252°/192° intake
.440" at 258°/196° exhaust
112° LCA
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2006 Mazda 6i (daily driver)
StrangeRangerVIP MemberPosts: 7553Joined: Fri Nov 08, 2002 6:54 pmLocation: Copley, OHTop
by 300 I6 » Fri Aug 19, 2011 9:08 am
Thanks guys that helps alot but what year chevy rockers do I buy fit my 300? Did chevy make a pedestal mount rocker or just studs?
by StrangeRanger » Fri Aug 19, 2011 11:16 am
You want the 1.75:1 rockers for a 194/230/250/292
No pedestal rockers for the C***y
by randysvan » Tue Aug 23, 2011 11:34 pm
Can anyone suggest a machine shop that is acquainted with this type of modification? I talked to one locally and they looked at me like I was nuts.
'86 Ford E250, 4.9, Carter YF, Duraspark 2
randysvanPosts: 47Joined: Wed May 11, 2011 8:06 pmLocation: Nashville, TNTop
by tom954x4 » Wed Aug 24, 2011 11:02 am
http://fordsix.com/forum/viewforum.php?f=50
machine shop recommendations
1995 F-150, 300-6, 4x4, ex-cab, sb, 3.08 5-speed, 2 1/2 in. exhaust w/flowmaster 50, MSD + ignition upgrades, canopy, 169,000 + miles Gone but not forgotten: 1965 F-100 240 3spd lwb "the green hornet"; 1991 f-150 300 5sp 2wd sb, 1960 F-250 4x4, 223 six, 4sp with wrap-around rear window, two-tone paint.
tom954x4Posts: 350Joined: Sun Nov 22, 2009 5:32 pmLocation: Twilight zone, WATop
__________________
Old 07-18-2012, 05:44 PM   #14
ThingyM
I found the "Knock".. There are a few teeth missing on the cam gear..Do ya think.??? hahaha.. Went to pull out the cam, Discovery time...I'm getting an Edellbrock Alum Manifold for the 4 barrel. And the exhaust header plates, I'll make my own headers...
Old 07-18-2012, 10:26 PM   #15
Old28
Old28's Avatar
Is it a fiber gear like the Chevy? Hope they make an aluminum replacement as I would never use a fiber gear again after the 194 motor problem.
After reading the material on the rockers, it looked like a simple job to convert to a rocker stud and roller rockers. You got the tools to do all the machine work.
Ya Dick, when I build the bigger motor I am going to run a 4bl carb, a lot more efficient than 5 - 94's.
__________________
Old 08-03-2012, 06:32 PM   #16
Old28
Old28's Avatar
What's happening on the car modification? Your keeping us in the dark for to many days.
Information & Pictures!!!!!!!!!!!!!!
__________________
Old 08-12-2012, 08:21 PM   #17
ThingyM
Well guys.. Haven't been feeling up to par lately, SO I went to the DRs and I get told that on the 15th of Aug. I get to have surgery and have my Gall Bladder removed.. DRs say I will be sore for a few days, But should be fine after that..Got some real plans for the swap.. See ya guys a little later....Dick..
Old 08-12-2012, 10:18 PM   #18
Old28
Old28's Avatar
Good luck with your surgery on Wednesday, you must be on a first name bases at that hospital. Give me a call when your out.
Still on for the ANRA race if you decide to take the altered. It's going to be hot/hot/hot like last time so don't push it.
__________________
Old 08-12-2012, 10:45 PM   #19
Toymaker
Old School HAMBer
Toymaker's Avatar
Dang it "DAD", get well!
Old 08-12-2012, 11:36 PM   #20
64 DODGE 440
Alliance Member
64 DODGE 440's Avatar
Hang in there Dick, we'll keep you in our thoughts. Heal fast.
__________________
Living the dreams of a points & condenser world.
HA/GR build: http://www.jalopyjournal.com/forum/s...d.php?t=189651
Life is good on the lunatic fringe, Tom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
