Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-08-2012, 12:04 PM   #21
BOSTONCAMARO
Senior Member
BOSTONCAMARO's Avatar
Default Re: Rocker Adjustment Big Block Chevy Solid Roller - need help!
how does a bump switch work? do tell, thanks!
online   Reply With Quote
Old 06-08-2012, 12:49 PM   #22
oj
Alliance Member
oj's Avatar
A 'bump switch' is generally built into the firewall, in the middle or one on each side, they are used to 'bump' the engine over so you can adjust the valves.
I tend to wire them in front of (electrically speaking) the main power switch so you can bump the motor and not have to worry about somebody turning the ignition switch 'on'.
__________________
'Molon Labe'
offline   Reply With Quote
Old 06-08-2012, 01:01 PM   #23
Traditions Racing
Old School HAMBer
Traditions Racing's Avatar
Build yourself a bump switch for the tool box as good as a Snap On one very easy. Buy a heavy duty starter push button switch, a few feet of 8 gauge primary wire and some equally heavy duty alligator clips to match the primary wire. A length of primary wire to each of the terminals on the switch and the other end to one of the clips. Shrink wrap the leads on the ends would be wise too. Now you just clip one end to the 12 volts battery lead on the starter solenoid and the other to the S or Switch terminal on the solenoid, hit the button and wallah!!.
M.S.D. and Jeggs both make excellent timing tapes if you insist on doing it that way. Remember timing tapes are like beer, you don't own it, you usually just rent it as the tapes fly off eventually at will just as you leak out the old beer. Speaking of beer.................
TR
Old 06-08-2012, 01:55 PM   #24
rustednutz
Senior Member
Now a question for you, How does a cam with a lot of duration or a wide lobe separation angle affect these methods of running the valves?
__________________
I was livin' the dream...then she elbowed me in the ribs and I woke up.
Old 06-08-2012, 01:58 PM   #25
BOSTONCAMARO
Senior Member
that is what I thought......a bump switch was, we have a starter seloid there, we can use that to bump it..and think we do have a bump switch
Old 06-08-2012, 02:26 PM   #26
Traditions Racing
Old School HAMBer
Snap-On Remote Starter Switch this is what we use at the track. Part # MT302BR.
If you build your own from my post above with say a universal starter push button from Speedway or Napa, remember one terminal on the back will always be HOT while it is connected and with some finessing you can make a nice insulated cover for the terminals ie large shrink tubing or a small length of heater hose.
I am absolutely with the crowd of when the EX opens adjust the IN, when the IN starts to close adjust the EX. It is easier than it sounds and absolutely correct.
Keep in mind, if you have not checked and corrected the TDC mark if your running a stock type damper, how accurate will be the timing tape for 90/180/270 degree marks as well.
Best of luck, TR
Click image for larger version
ID:	1659151   Click image for larger version
Old 06-08-2012, 02:58 PM   #27
BOSTONCAMARO
Senior Member
it is a quality aftermarket balancer but not fully degreed
thanks, i am going to look into that bump switch
Old 06-08-2012, 04:03 PM   #28
Traditions Racing
Old School HAMBer
BOSTON, yes I was assuming you had a aftermarket balancer, but and here is the clincher, is the POINTER adjustable and verified it coincides with true TDC? That is the key my friend. You can run the best balancer in the world, but you must have the TDC pointer verified with the mark on the damper. If your pointer is off, then the true TDC is off, and then if you put a timing tape on or even a balancer with 90 degree segements marks out, they will all be off accordingly, make sense?
You dont need a fancer high dollar adjustable pointer either especially on a Chevrolet. A $2.99 Mr. Gasket pointer and a pair of tin snips is all you need. Once you establish TRUE TDC, trim the el-cheapo pointer with the tin snips so that you have a point that faces to the front of the engine, that coincides with the TDC mark on the damper. Remember you no longer need the window and the other marks on the tab, only a point that lines up with true TDC. Shoot your timing now with the point and the amount of TOTAL timing you will run and read it directly off the damper. Say you want 36 degrees TOTAL all in at 3000, rev her up to just past 3000 RPM's, shoot the timing light at the 36 degrees and the tip of the new pointer you trimmed out, or turn the distributor as needed. Hope that helps.
TR
Old 06-09-2012, 07:47 AM   #29
BOSTONCAMARO
Senior Member
yes it is....adjustable and confirmed...just we have been away from this awhile, we should be all set now, thank you for the help! we should have it running later this week, my parents are in Maine for a few days and I am tied up with my son (2 year old)
Old 06-13-2012, 10:43 PM   #30
BOSTONCAMARO
Senior Member
adjusted tonight. did it cylinder by cylinder in 90 degree increments following firing order all looks good! thanks again..took some time. but was right way
Old 06-19-2012, 09:37 PM   #31
BOSTONCAMARO
Senior Member
Got the car running tonight!!! at first it had a little clickity clackity, one adjuster either backed off or we didnt have it tight enough, set it up on number 1 again, set that one exhaust valve car started and ran like a monster! also through the belt...still needed to alight stuff a bit straighter, ended up eating the flex fan...got it all apart now and new parts on way tomorrow....
anyway the car runs great, ran 11 degrees of initial timing (have 7AL and timing computer with dial) and still need to tune carb, but man it sounds sick and VERY healthy through the Corvette sidepipes....
Thanks again to all those who posted, we should have the car on the road soon...now onto the brakes..
Old 06-19-2012, 09:43 PM   #32
BOSTONCAMARO
Senior Member
my dad, presetting idle screw before its second start as it was backed down too much...an off the shelf 850 that will eventually see some jets etc, but for now just want to get it on the road.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
