Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-19-2012, 08:12 PM   #1
Zigged, should've Zagged
Newbie
Zigged, should've Zagged's Avatar
Cool Floor pan replacement
I was looking for some insight into floor pan installation. Should I butt weld them in, or should I overlap some metal and pop rivet them along with silicone. If i over lap the metal should the pan be on top of the original floor or underneath?
offline   Reply With Quote
Old 06-19-2012, 08:15 PM   #2
tb33anda3rd
Old School HAMBer
tb33anda3rd's Avatar
Default Re: Floor pan replacement
no pop rivets, no silicone.
__________________
my favorite color is rust!
Old 06-19-2012, 09:13 PM   #3
davidbistolas
Alliance Member
davidbistolas's Avatar
I don't see why lap welding isn't an option for you if you're willing to rivet & silicone?
Old 06-19-2012, 09:27 PM   #4
50dodge4x4
Old School HAMBer
Cut the rust out until you get to good metal, clean up the original pan, put the new one on top with about 1/2" over lap, and weld it in. Seal the edges with seam sealer, then paint the floor. Most of the rusted out floors rust out from on top, from inside of the car/truck. Gene
online   Reply With Quote
Old 06-19-2012, 09:31 PM   #5
redsdad
Grenade Inspector
redsdad's Avatar
IMHO
If you are putting in like replacements of a stock floor and the stock floor was lapped, you should lap at the stock locations. Preferably with spot welds like stock. Rosettes if you can't spot weld. All other welds should be butts. Rivets only for holding things together while you weld them. Better yet - clecos. Rivets removed and the holes filled with weld at the end. Never silicone.
Old 06-19-2012, 09:33 PM   #6
shadams
shadams's Avatar
Yea, no rivets. Believe me, it isnt as hard as you think. I cut my whole f'n floor out so my pillars were just swinging in the breeze and was scared as hell but got it done. Weld those puppies in. In some cases, the factory laps the joint such as where the floor goes over the rocker panels and then they used spot welds. I used a spot weld cutter to remove the welds and that leaves a nice hole to fill in when welding. But rivets and silicone is GHETTO no matter which way you look at it.
__________________
1950 3100 Build Thread
http://www.jalopyjournal.com/forum/s...d.php?t=572898
Old 06-19-2012, 09:51 PM   #7
spiders web
Grenade Inspector
spiders web's Avatar
Butt weld and use a copper spoon to help with warpage. seal with seam sealer and paint with por 15. Use a good sealer primer then paint. You will be glad in the end.
__________________
I'm adapting to technology at Glacial speed!!!!!!!!!!!!!
Old 06-20-2012, 08:25 PM   #8
Newbie
OK I'm getting the picture. Welding it will be. Thanks for the input.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
