Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 05-04-2012, 04:35 AM   #1
Lucky444
Senior Member
Lucky444's Avatar
Default 1 3/8" Exhaust Tubing On An Inline 6 ?
I have poured over all the exhaust sizing threads I could find on the HAMB and have played around with my exhaust many times in search of that perfect "tune".
Here's what I have right now...
250 Chevy Inline 6.
Split stock manifold.
1 3/4" pipe.
2 Brockman's 17" body/24" overall steel packs.
Run all the way to the back, exiting through 2" pencil tips.
I originally ran it with one straight pipe and one steel pack, but my Chevy is a daily driver and the straight pipe started to make me crazy, AND deaf when on the freeway. Now with two steel packs the decibels are manageable, but it doesn't have the same character. My plan is to neck the tubing down about the last three feet of exhaust. I'm thinking of using 1 1/2" or 1 3/8" tubing for the final run to the new 1 1/2" pencil tips I bought just to give it a slightly higher pitch. Right now it's a little too throaty. In all the threads I checked out, nobody mentions using 1 3/8" pipe.
Question: Is 1 3/8" tubing excessively small? Do you think there will be much of a sound difference between the 1 1/2" and 1 3/8"?
My rolling project.
Thanks,
Jason
offline   Reply With Quote
Old 05-04-2012, 06:57 AM   #2
tommy
Old School HAMBer
tommy's Avatar
Default Re: 1 3/8" Exhaust Tubing On An Inline 6 ?
1 3/8" exhaust pipe does not exist. 1 1/2, 1 3/4 and 1 7/8 are the smaller sizes for exhaust tubing. You won't find it because it is not made. If you find something that small you won't find elbows or a bender to do anything with the pipe.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 05-04-2012, 11:28 AM   #3
Lucky444
Senior Member
Lucky444's Avatar
I did see 1 3/8" and 1 1/4" SS exhaust tubing made by Patriot and listed at JEG's, but was also thinking about using regular steel tubing I found at a metal supplier locally. They have something that's 1 7/16" OD, 20 g, with a 1 3/8" ID. Didn't think about the bender availability though. Also, I assumed that early Japanese cars like Datsun's and Toyota's must have run pretty small diameter exhaust tubing too.
Old 05-04-2012, 11:55 AM   #4
dad-bud
Senior Member
dad-bud's Avatar
Smaller diameter equals higher gas velocities equals higher pressure drop equals less power and worse mileage.
Use 2" and get a decent muffler if you're concerned about it being too loud, you will get a little more power.
Costwise - forget it, you won't save anything by going smaller diameter.
My $0.02 anyway.
Good luck - by the way, your car looks good.
Old 05-04-2012, 02:55 PM   #5
Lucky444
Senior Member
Lucky444's Avatar
Thanks. Not thinking economy or performance really. The two steel packs offer plenty sound managment. Just looking for the perfect "6" sound. A little rap and pop. Hoping one of you Bomb guys will know.
Old 05-04-2012, 05:47 PM   #6
Lucky444
Senior Member
Lucky444's Avatar
Yeah sorry, when I wrote, "in search of the perfect tune" I was talking about musical tune. Had to clarify. Not trying to performance tune the car, I'm just trying to get the sound out the pipes right.
Thanks.
Old 05-04-2012, 06:12 PM   #7
Frankie47
Senior Member
Frankie47's Avatar
How about 2 different size steelpacks instead of a straight pipe...............
__________________
1947 Dodge CC
The man's prayer
I'm a man, I can change,
If I have to,
I guess....Red Green.
Old 05-04-2012, 06:14 PM   #8
Hogride
Newbie
Hogride's Avatar
4 speed man Has Harley fish tails on his 54 I 6 sounds cool as hell ! just a thought for you
Old 05-04-2012, 07:24 PM   #9
Road Runner
Senior Member
Road Runner's Avatar
Once you install mufflers, even short ones, the sound changes, as you remove a lot of it.
Smaller diameter tailpipes will give you a thinner, brighter version of what's left.
No exhaust with any style of mufflers will sound anything like straight pipes of any diameter or length, especially with chevy 6s - even later ones that flow better and more quiet at higher rpm.
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
Old 05-05-2012, 01:38 AM   #10
Lucky444
Senior Member
Lucky444's Avatar
Lightbulb Re: 1 3/8" Exhaust Tubing On An Inline 6 ?
Quote:
I actually have a single shorter (12") steel pack that I'm going to start with on one side to see how the sound changes.
[QUOTE=Road Runner;7734704]Once you install mufflers, even short ones, the sound changes, as you remove a lot of it.
No exhaust with any style of mufflers will sound anything like straight pipes of any diameter or length, especially with chevy 6s - even later ones that flow better and more quiet at higher rpm.[/QUOTE
I don't miss the straight pipe so much anymore, but your description of a thinner and brighter sound is a good one.
I'm still curious if anyone has run something smaller than 1 1/2" diameter tubing. Anybody?
Old 05-25-2012, 04:10 PM   #11
bodi
bodi's Avatar
I have not run the smaller tubing, and am planning to do exhaust on my 64 c10 with a 292 starting tomorrow. I'm going to be running 2 1/4" out of the split headers immediately in to 2" inlet-outlet 30" long Cherry bombs, and then 2" the rest of the way out. I've heard it said that the split 6 manifold guys like the 1 7/8" for the cackle and rap on tip out. I'm not aiming for all that.
As for dies for 1 3/8", my Ben Pearson MC58 machine has a set of 4" radius with long, and short shoes, so, yes they do exist.
__________________
Build it, don't buy it.
online   Reply With Quote
Old 07-13-2012, 03:45 AM   #12
Lucky444
Senior Member
Lucky444's Avatar
Thanks for that info bodi.
I welded in the shorter 12" steel pack I had, so now it's 17" on one side and 12" on the other and still running through 1.75" tubing all the way out back.
Now I've got a good balance between two worlds. It still raps and pops like it did with one straight pipe on one side, but toned down a good amount. Not as harsh on the freeway!
Still considering using 1.5" tubing for the last couple of feet of exhaust.
Old 07-13-2012, 04:25 AM   #13
bodi
bodi's Avatar
Good to hear you are happy with your results.
Any guesstimate how close your mufflers are to the actual head? I staggered my Cherry Bombs as I had read that doing so would make each bank sound different giving a better split manifold sound. I had read that the further forward you had the muffler, the more cackle and pop you would get. That holds true on my rig. My driver's side muffler is about 36" away from the exhaust valves, and it cackles like crazy. The other side is nearly twice the distance, and is pretty subdued.
I think some of the cackle may be coming from my exhaust/intake gaskets not sealing properly. Have to do more research on a possible better gasket.
Sure is fun stuff to play with!
__________________
Old 07-13-2012, 11:51 AM   #14
TexasHardcore
Old School HAMBer
TexasHardcore's Avatar
Location of the mufflers will affect sound more than changing the last couple of feet of tubing.
__________________
Tune Up or Tune Out.
Old 07-14-2012, 02:43 AM   #15
Lucky444
Senior Member
Lucky444's Avatar
Yessir, been having fun changing my exhaust system for the last five years! Like tuning an instrument.
I staggered my steel packs too. The longer one is closer to the manifold. Probably about 36" as well. The shorter one is only about 6"s further back. They sit right about under where my feet sit. I did experience more snap, crackle, pop when there was an exhaust leak. I think the added O2 did something to the mixture or the way the unspent gasses burned off in the tubing.
I have had really good experience with the "thick gasket" I got from Cliffords Performance. Seals and conforms well to both surfaces.
Quote:
With wanting to change the last few feet of tubing, my goal is to change the tone. Right now I'm happy with the amount of rap and decibels it's putting out. Just like musical instruments I want to change the diameter of the tubing so I can go from a Trombone to a Trumpet. Just a slightly higher pitch and crisper sound.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
