Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
View Poll Results: Best FoMoCo street motor, circa 1961
1948-1951 Lincoln/Truck Flathead 3 3.70%
1949-1953 Ford/Mercury Flathead 23 28.40%
1952-1961 Lincoln/Truck Y-block 4 4.94%
1954-1961 Ford/Mercury Y-block 32 39.51%
1958-1961 Ford/Edsel/Mercury FE 10 12.35%
1958-1961 Mercury/Edsel/Lincoln MEL 9 11.11%
Voters: 81. You may not vote on this poll
Reply
Thread Tools Display Modes
Old 05-01-2012, 11:40 AM   #21
FrozenMerc
Senior Member
FrozenMerc's Avatar
Default Re: Best Ford power for your Model A, circa 1961?
In '61, Both the Flathead and Y-block would have been Cheap, Easy, and Reliable. But for pure smoke the tires, go way to fast fun, unlimited budget, the 1958 400 HP Super Marauder (430 MEL) would be the way to go.
Fun Poll and thought experiment though.
__________________
"One Test Result is Worth One Thousand Expert Opinions" - Wernher von Braun
offline   Reply With Quote
Old 05-01-2012, 12:21 PM   #22
scrapiron
Alliance Member
Move up a couple years and go with a SBF, most bang for moderate weight gain, if any.
__________________
Progress was all right once, but it has gone on too long,,,
Old 05-01-2012, 02:01 PM   #23
Bruce Lancaster
Alliance Member
Are we talking a Model A with basically stock layout or one that can have extra wheelbase?
FE and MEL are heavy and large, with extra length added in front casing. Length would make them a hard install in a Model A of stock wheelbase, and they may even be too wide to recess into the wall.
Lincoln FH is also heavy and bulky and not all that powerful. Practically no one was interested in that route then.
Y block is closest modernish Ford fit, but is a worse fit than the older and usually bigger displacement/more power potential Cad and Olds choices. Those engines are not bad in length and overall fit and might even leave you room to bring your feet with you when you get into car. Older versions of these were the cheap choice for modern power in '61 too, newer versions are same bulk with lots more power and displacement. Ever notice that by '55 the soup your Y articles disappear from magazines and are replaced with swap your Y for anything GM or Chrysler articles???
The hot and actually expensive choice in '61 would have been the SBC...it had been recognized as the perfect replacement for the flathead, and was still expensive because every one that hit the junkyard was IMMEDIATELY sold to a rodder...yes, 283's and even 265's were still actually scarce used in '61 because demand was practically infinite. The later and the more Vette goodies the more expensive; a good running takeout fronm a wreck was almost as expensive as a crate one from the dealer!
__________________
Bruce
Old 05-01-2012, 02:13 PM   #24
Fenders
Old School HAMBer
Fenders's Avatar
Quote:
Originally Posted by need louvers ? View Post
None of the above... small block Chevy! Heh Heh...
That is the last motor I would put in my ride today (too belly button) but although you may have said that in fun, I believe in 1961 that would have been the most popular motor of choice.
__________________
Faux-tina can be bought.
Patina must be earned.
Old 05-01-2012, 02:24 PM   #25
Bigcheese327
Alliance Member
Bigcheese327's Avatar
Quote:
It must be a cultural artifact that if I had a '52-'53 Ford I'd want to install a Cadillac V8. That and Fordillac is fun to say.
How do the dimensions on an Olds 371 or Cadillac 365 line up against the SBC?
__________________
"Black-wall tires, they blend into the pavement, but these white-wall tires, they say look at me, here I am, love me."
Old 05-01-2012, 02:52 PM   #26
Bruce Lancaster
Alliance Member
A bit wider, only a little longer with simple front accessories. Very compact for basic designs that can go way beyond 400CI
(PS...both are heavier than SBC, the Olds by the most. Good and bad...heavy but has room for massive overbores and has very strong block webbing)
(Best Olds parts and interchange guide was pubished in Popular Hot Rodding, circa early 1960's)
__________________
Bruce
Old 05-01-2012, 04:34 PM   #27
flatheadz-forever
Grenade Inspector
flatheadz-forever's Avatar
tri power flathead
tri power 390 hp
tri power 312 with thunderbird valve covers
cant go wrong with any of the above a ford belongs in a ford and a mopar in a mopar chevy in a chevy glad to see your pole doesnt include sbc I compare guys who put sbc's in their hot rods with yankee fans they get on the bandwagon just because everyone else is doing it doesnt mean you have to good luck keep a ford in it
__________________
Wanted:30-31 Ford Pickup.(rear fenders)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
