Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-20-2012, 10:58 AM   #1
Scotch Buzzard King
Senior Member
Scotch Buzzard King's Avatar
Default 1940 Dodge Truck Build (Finally!)
I started with a beat up cab and went from there. I found a parts truck to help me with the build. I've spent the last month cutting all the ugly from it and finally got down to a good base.
Someone chopped the cab with an axe, and I've spent the last six months looking for new doors and a roof. I've finally found all of the parts I've been looking for, and I'll just fabricate the rest once I blow the dust off my welder.
I've got pictures from what it first looked like as I saw it on Craigslist, the parts truck as it first looked on Craigslist, the cab in storage, the cab with all the replacement parts, the parts truck with all the ugly gone, and a picture of what I'm going for in this build. Enjoy.
Click image for larger version
ID:	1594826   Click image for larger version
Name:	The Beast 01.jpg
ID:	1594827   Click image for larger version
Name:	The Beast 03.jpg
ID:	1594829   Click image for larger version
ID:	1594830   Click image for larger version
Name:	Dodge WC1 Half Ton.jpg
__________________
"This is no dress rehearsal, we are professionals, & this is the big time."--Waylon Jennings
offline   Reply With Quote
Old 03-20-2012, 11:11 AM   #2
T Hudson
Senior Member
T Hudson's Avatar
Default Re: 1940 Dodge Truck Build (Finally!)
I like it. Have you got more build photos to share?
__________________
If I call you a tool, don't assume you are useful.
Old 03-20-2012, 01:22 PM   #3
Scotch Buzzard King
Senior Member
Quote:
I will in time. I've got to narrow and shorten the frame, stitch the cab together, and fab up engine and transfer case mounts. A lot more pictures are coming. I'm going to post some of the "What Not To Do" photos before I post the pictures of how I fixed those problems. And I've got some Duesy's!
I'm aiming for a year end completion, so when the build photos come they will be coming hot and heavy.
__________________
Old 03-26-2012, 08:58 AM   #4
Scotch Buzzard King
Senior Member
I finished some work over the weekend, and now I have some more pictures. This is the perfect example of how not to modify an axle for a frame:
ID:	1599226   Click image for larger version
ID:	1599227   Click image for larger version
ID:	1599229   Click image for larger version
ID:	1599230   Click image for larger version
__________________
Old 03-26-2012, 09:00 AM   #5
Scotch Buzzard King
Senior Member
Here's what a haircut will do for shitty workmanship:
ID:	1599234   Click image for larger version
ID:	1599235   Click image for larger version
__________________
Old 03-26-2012, 09:03 AM   #6
Frankie47
Senior Member
Frankie47's Avatar
I love trucks and yours is coming along fine...but it's not a hotrod or a custom...4wd?
__________________
1947 Dodge CC
The man's prayer
I'm a man, I can change,
If I have to,
I guess....Red Green.
Old 03-26-2012, 09:09 AM   #7
Scotch Buzzard King
Senior Member
At least the guy welded the shit work on top of the original spring perches. I'm going to shave the top of the perches down just enough to weld my new perches over. I'm going to have to modify my perch for the passenger side to fit over the old one. I'm converting the spring perches on the front and rear axles to 2.5" springs as to give myself a better selection of parts from which to choose. I looked everywhere for the original style 1.75" springs that came on the front, but I couldn't find anything reasonable. I figure that I already have 2.5" springs on the frame as it is so why not modify the frame to axles? Next stop, narrowing the frame.
__________________
Old 03-26-2012, 09:14 AM   #8
Scotch Buzzard King
Senior Member
Quote:
You are correct. I figure that since most of the parts are from WW2 that I'm using, including my axles and transfer case, it's nice to see something different every now and then. Oh, did I mention that I don't know shit about 4x4's and everything I'm learning is as new to me as to some of you? I make it look easy huh?
__________________
Old 03-26-2012, 09:41 AM   #9
Frankie47
Senior Member
Frankie47's Avatar
Quote:
The only thing I know is 2 metal thingies stick out of the lump doohickey and turn the rubber and metal dealies at the same time
__________________
1947 Dodge CC
The man's prayer
If I have to,
Old 03-26-2012, 10:01 AM   #10
73RR
Old School HAMBer
73RR's Avatar
uugh oh...I always thought that they were 'dualies'..
I am a bit worried about the longevity of this thread give some of the recent closures. Traditional. Hotrod. That sort of stuff.
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 03-26-2012, 10:22 AM   #11
B Ramsey
Grenade Inspector
B Ramsey's Avatar
is that a military cab? im on the lookout for one, if you know where one is. an easy way to tell is the panel under the doors, military ones are taller.
Old 03-26-2012, 10:25 AM   #12
B Ramsey
Grenade Inspector
B Ramsey's Avatar
your pictures of the front axle make my head hurt....
Old 03-26-2012, 10:47 AM   #13
Scotch Buzzard King
Senior Member
Quote:
It would be sad if they did close it. I thought about hot rod-street rod on this build, but I thought I'd be different. It's got a flathead, just not the cookie-cutter Ford Flathead. That one's going in the T-Bucket. !
Quote:
No its not. It's just an old 1940 Dodge cab I picked up off of Craigslist for pocket change. I've spent the last eight months tracking down the correct WW2 parts for this truck, but the total build is going to be a tribute to the war design rather than a military vehicle restoration.
Right! And the guy DROVE the truck with the axle like that!
__________________
Old 03-26-2012, 11:07 AM   #14
1950-mercury
Alliance Member
1950-mercury's Avatar
I like it!!!
__________________
"Remember once you crush 'em their gone forever"
Old 03-26-2012, 12:34 PM   #15
Scotch Buzzard King
Senior Member
Quote:
Originally Posted by 1950-mercury View Post
I like it!!!
Thank you. I like your Mercury.
__________________
Old 06-28-2012, 10:38 AM   #16
Scotch Buzzard King
Senior Member
Many things have happened since my last post, but I found this thing to help me with the build. Got it for cheap too.
__________________
Old 06-28-2012, 10:50 AM   #17
66Newport
Old School HAMBer
66Newport's Avatar
Sweet! I dig it! I love the look of the old beast, have always wanted one.
__________________
1Timothy 1:15 Christ Jesus came into the world to save sinners—of whom I am the worst.
Old 07-16-2012, 09:08 AM   #18
Scotch Buzzard King
Senior Member
Had to change horses midstream. I found out that my WW2 front axle was warped. It was so bad that it went from having a turning radius to not once the repairs were made. I had to scrap that idea and go with something new. I decided to still keep the 4x4 idea, but build it as a regular civilian truck instead. Here's what I have so far:
ID:	1691680   Click image for larger version
ID:	1691681   Click image for larger version
ID:	1691683   Click image for larger version
__________________
Old 07-16-2012, 09:09 AM   #19
Scotch Buzzard King
Senior Member
I shit-canned my old frame in favor of a K5 Blazer frame. I had to build new body mounts, but I don't have any pictures of those at the moment.
__________________
Old 07-16-2012, 09:47 AM   #20
B Ramsey
Grenade Inspector
B Ramsey's Avatar
i have a 1941 front axle in the scrap pile....also some beatup front fenders and a frame, and rear axle.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
