Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-20-2012, 11:11 AM   #1
Hdonlybob
Old School HAMBer
Hdonlybob's Avatar
Default Model A Front Wheel Options
OK folks,
I am totally in the dark on details for my latest '26 Model T project.
I am going to look at several front/rear ends that a friend has later this week.
I set it on a Model A frame.
Some basic questions:
* If I buy a front end with bare spindles, what is required to get it to a decent brake system using modern type wheels?
* If I buy a complete front, with drums, wheels etc, what will be reqired to get decent hydraulic brakes ?
* I assume a standard Model A rear end set up will not work with the torque of a 283 motor?
I have a sbc 283 and a Saginaw 4 speed for it....
This will be a driver also, nothing special.
Also as all my projects are, this is a budget build. Can't afford aftermarket parts...
As always thanks for any help/advise you can give me...
Cheers,
Bob
offline   Reply With Quote
Old 03-20-2012, 12:54 PM   #2
bagged chevy
Grenade Inspector
bagged chevy's Avatar
Location: from the land of pornstars and crackheads, SoCal...
Default
Well it all depends if you want to go traditional with this build or non traditional. I would look for the following:
Traditional:
As far as front axle width and drop that's personal preference
Split wishbones
1940-48 ford brakes
Round back spindles
Later model 1940-48 banjo rear end preferably I believe it's a 46-48 truck open drive.
Non traditional:
Same for the front end above, but I believe you can buy disk brakes though for ford spindles if you wan. To go that route.
Rear end nine inch ford nothing better. Early broncos had the perfect width to fit under the rear and look right.
Taking the hamb to the streets
__________________
NEED PINSTRIPING?
http://www.jalopyjournal.com/forum/s...d.php?t=630125
Old 03-20-2012, 06:11 PM   #3
Hdonlybob
Old School HAMBer
Hdonlybob's Avatar
Default Re: Model A Front Wheel Options
Thanks for the quick info...
A bit more clarification...
Wanting to go pretty much traditional, using Model A front spring/axle etc.
Rear end will not matter much. I actually have a '55 Chevy rear end housing that I can start with.....
Also today found a real nice Chevy old style Power Glide trans that I can trade my Saginaw for....I may go that way for the ease of installation as well as wife being able to drive...
BTT for night crowd...
Cheers....
Sponsored Links (Register now to hide all advertisements)
Old 03-22-2012, 04:25 AM   #4
bagged chevy
Grenade Inspector
Default
No problem! As far as wheels go for your build you said that you can't afford aftermarket. That shouldn't be a problem though, that rearend for that Chevy should be 5 on 4.5 bolt pattern, so you could go with Americans or steelies, its all personal preference. But I would run a 15 or 16 inch wheel. The thing you're going to run into if you decide to use early ford brakes up front, is those are a total different bp at 5 on 5.5
Any questions don't hesitate to pm me.
Bagged chevy
__________________
NEED PINSTRIPING?
Old 03-23-2012, 08:37 PM   #5
oldschool66
Senior Member
oldschool66's Avatar
Location: The Garage with the lights on in Richland Center Wisconsin
Just so ther'es no confusion, the Chevy wheel bolt pattern is 5 on 4.75, not 4.50.
__________________
Tomorrow is promised to no one
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
