Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > Events > H.A.M.B. Drag Nationals > HA/GR
Reply
Thread Tools Display Modes
Old 03-12-2012, 07:38 PM   #1
Third DodgeBrother
Grenade Inspector
Third DodgeBrother's Avatar
Default Miss Serendipity
I don't usually do build logs until I'm done, because my builds have a tendancy to wander off into left field and fade away. Counting on you guys to keep me straight, and help through the rough spots. A kick in the rear, or a pat on the head as needed.
Where I'm at:
Got the stone axe [300 Ford six] unloaded and undressed
Shaved the brackets on the S10 posi rear
Ordered a stick of 1 1/2" x 3" x 3/16" tube. Steel yard looking for 6" pipe drops for driveshaft loops and gonad guard.
Axle, spindles, split wishbones: due Weds, spring shipped.
Tin seat, fuel cell, and vega steering box ready
NHRA rulebook on order
Pictures to follow
offline   Reply With Quote
Old 03-12-2012, 08:00 PM   #2
Old6rodder
Alliance Member
Old6rodder's Avatar
Default Re: Miss Serendipity
Cool, another one under way.
Don't forget to send me some specifics and a picture when you're ready, so I can add yours to the photo & info thread.
Yes, parts piles & intentions do qualify for the thread.
__________________
Dick, 225% crazy
Cassi, El Toad & Flyin' Brick II
I've raced.
I've driven normally.
I prefer racing.
Old 03-12-2012, 10:01 PM   #3
Old28
Old28's Avatar
Glad to see that we have another SDRA car being built. As I have said many time on my thread, I do pictures better than writing so the more the better. Are you going to run a C-4, C-6 or a glide for a trans?
One of the group in the Pacific Northwest cars is running a 300 Ford. If I recall he was running 11.50 - 11.75 with pie cut nostalgia slicks. Would love to see what it would run on 6" street tires.
Remember "Pictures, Pictures, Pictures"
__________________
Build It - Race It - Have Fun
"I'd Rather Be Racing"
Old 03-13-2012, 12:17 PM   #4
Third DodgeBrother
Grenade Inspector
Pictures as promised
Click image for larger version
ID:	1589408   Click image for larger version
ID:	1589409   Click image for larger version
ID:	1589413   Click image for larger version
Old 03-13-2012, 07:50 PM   #5
Old28
Old28's Avatar
Looks like a good start on parts. I like those mid 30's wide five spindles and wheel.
Are you going to modify that intake and run 6 one barrels?
Keep us all in the loop as we love to see a build move forward.
__________________
Old 03-13-2012, 10:08 PM   #6
Third DodgeBrother
Grenade Inspector
I thought I was going to run a C6, unfortunately I couldn't tell the difference between C6 and E4OD. I can now! I'll have to see how the guys in Tulsa feel about stand-alone tranny-control computers.
I'd love to go with stacked fuel injection on this motor, but ... that isn't quite within the rules either. Seems like a natural spot for a homemade box plenum type manifold. I've got a pair of Holly/Weber progressive two barrels that might be legal. I'm not sure what four barrel I could use.
The wheel is swap meet '39, on a modern JFZ wide five hub, borrowed for mock up from Miss Enid (my avatar). I've been looking forever for the adapter snouts to Ford spindles, without any luck. Plan B is empty Ford wide five hubs and drums, like Marty Strode used.
Old 03-13-2012, 10:35 PM   #7
ThingyM
I got a set of those..
Old 03-14-2012, 02:24 AM   #8
CrkInsp
DodgeBrother, Wish I could say you could run that trany, BUT sorry, no computors.
Yes, you can run those carbs. Most any 4bbl. carb is ok. I think a vac. sec. carb has a lot of advantages in launching the car to prevent wheel spin. Thanks for asking your questions as they help other people wanting to build these cars.
Old 03-14-2012, 07:47 AM   #9
Third DodgeBrother
Grenade Inspector
ThingyM : PM sent.
Plan C is repop Ford hubs with space saver spares!
Anyone need an E4OD?
Old 03-14-2012, 12:55 PM   #10
Third DodgeBrother
Grenade Inspector
Axle arrived. Stone axe on dolly. Off to Goodguys Lonestar. Hopefully will be able to steal some ideas, and score some swap meet treasure.
ID:	1590283   Click image for larger version
Old 03-14-2012, 05:53 PM   #11
Kenneth S
Senior Member
Kenneth S's Avatar
Run a 1972-78 C4 that was behind a 302, or 351W, the C4 eats less HP than a C6, or E4OD
__________________
Ford 2.3L Lima engine guide.
http://www.jalopyjournal.com/forum/s...36#post3389436
Old 03-14-2012, 06:27 PM   #12
Third DodgeBrother
Grenade Inspector
The Seven Point Frame Program
-Get stick of 1 1/2" x 3" x 3/16" tube ($74.00) Check
-Cut in half Check
-Add cross members
-Cage mock-up, order hoops
-Weld hoops
-Fab and install brackets
-Leave on the last yellow
The Acme gas rail kit
Old 03-14-2012, 06:37 PM   #13
64 DODGE 440
Alliance Member
64 DODGE 440's Avatar
The tubing looks good sitting on the roll cage like that.
__________________
Living the dreams of a points & condenser world.
HA/GR build: http://www.jalopyjournal.com/forum/s...d.php?t=189651
Life is good on the lunatic fringe, Tom
Old 03-14-2012, 06:45 PM   #14
Third DodgeBrother
Grenade Inspector
Amen, brother. Do you ever get tempted, to section out the center third of your bucket, and just forget all about tinwork?
Old 03-14-2012, 10:58 PM   #15
Joe Hamby
Joe Hamby's Avatar
How old are you? The first two Dodge Brothers both died in 1920. We have a 27 Dodge coupe sitting in my friends shop, with a 53 Chrysler hemi in it. the owner died last summer. It is for sale by his wife, I think it is or was on Craigs list (Tulsa). We hope that you will race with us in Tulsa.
If I had your E-Mail, I could send pictures. not trying to sell, just thought that you might like to see them. Joe
Old 03-15-2012, 06:52 AM   #16
Third DodgeBrother
Grenade Inspector
I'm 61. I only feel old enough to have died in 1920! I plan on racing in Tulsa, but then, at my age, I'm too old to plan buying green bananas!
Old 03-15-2012, 10:11 AM   #17
64 DODGE 440
Alliance Member
Quote:
Damn Kids! I'll be 66 in April. You are only old if you make your mind up to be old. I may be growing older, but I damn well refuse to grow UP! Keep at the build, it will help keep you young.
__________________
Old 03-15-2012, 04:12 PM   #18
ThingyM
Sh--t You guys are still kiddies,, I'll be 77 in a few months. But 47 at heart..Still thinking as to what I should put in my chassis for an engine,, But it will be SDRA allowed engine and trans..
Old 03-15-2012, 04:31 PM   #19
Old6rodder
Alliance Member
Old6rodder's Avatar
Quote:
Yeah, I still have a hard time keeping the snot wiped off my nose.
Thingy, I'm glad you're keeping the car. The SDRA guys out here can use another racer, and you're a good one. I'm looking forward to lining up with you again.
3DB, your parts pile's looking like it might just become a car.
Gentlemen (and you too, Thingy ), every HAMBster built (whether HA/GR or SDRA) helps both classes.
__________________
Dick, 225% crazy
I've raced.
I prefer racing.
Old 03-16-2012, 10:55 AM   #20
64 DODGE 440
Alliance Member
You have the right attitude Dick, Peter Pan is a good role model. Find the engine and trans you want and get back at it. Racing keeps us young!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
