Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 01-19-2011, 11:33 PM   #21
jbtine
Alliance Member
jbtine's Avatar
Default Re: 273 mopar engine looking for info
It's not true that you can't get pistons for the 10.5:1 4bbl engine. Egge has them listed from standard bore all the way to .060 over however the cost listed is $428 for a set. Bad thing about a 273 4bbl engine is finding gas to run in a 10.5 engine. You can build a 318 cheaper and have more power. They even use the same crank, the 273 with a smaller bore uses a much thicker wall wrist pin to make up the difference in balance. You can build the 318 and pull 400hp. Here are a couple of builds.
http://www.hotrod.com/howto/113_0304...ild/index.html
http://www.popularhotrodding.com/eng...ine/index.html
offline   Reply With Quote
Old 01-19-2011, 11:41 PM   #22
jbtine
Alliance Member
jbtine's Avatar
Another thing as stated in previous posts is the difference in intake angles. This includes a bolt size change too. 64-65 uses 5/16 bolts and 66 up including 318,340 and 360s use 3/8 bolts. I doubt anyone still makes intakes for the 64-65 engine. If you are lucky to find an Edlebrock the number is LD-4. 66 up engines 273 and 318 uses the LD-4B and many other brands too.
Old 01-20-2011, 12:14 AM   #23
wrenchbender
Grenade Inspector
wrenchbender's Avatar
I run a 273 with a turbo on it in my 64 afx dart at the hamb drags this last year and it smoked the tires the entire 1/4 mile mine has 340 heads and intake along with a six pack cam also has flat top pistons runs real good and has been super reliable I drive it everyday to work and everywhere else I wouldn't be afraid of running a 273 they are high winding and make good power for a small cube motor
__________________
Chrome don't get ya home
Sponsored Links (Register now to hide all advertisements)
Old 01-20-2011, 05:04 AM   #24
REJ
Senior Member
REJ's Avatar
Either through Jegs or Summit you can get the 64-65 intake. Be prepared to pay for it though.
Last time I checked they were around 400-500.
__________________
If you are driving down the highway at light speed and turn on your headlights, what happens?
MOPAR HA/GR on the track!!
Old 01-20-2011, 06:20 AM   #25
OldBlueOval
Grenade Inspector
OldBlueOval's Avatar
Thanks for all the info!! (what a great place) Now I have to decide. There is a complete 440 set up near me, or I can go with the 273 set up? All I want to do with the car at first is to cruise the streets and enjoy the ride and get it on the road!! Thanks Joe
Old 01-20-2011, 09:52 AM   #26
OldBlueOval
Grenade Inspector
With the small block 273 with the distributor in the rear would you have too recess the stock firewall.
Old 01-20-2011, 10:00 AM   #27
73RR
Old School HAMBer
73RR's Avatar
Use the 440. In dead stock form it will scare ya.
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 01-20-2011, 10:03 AM   #28
Rodhotz
Senior Member
Rodhotz's Avatar
Quote:
Originally Posted by Deuces View Post
........ Or before it blows up??? That ain't no way to treat a classic motor!!
It's so classic we took 5 of them to the scrapper a few months back. But we did keep the formula "S" motors.
__________________
Never put off today what you can put off till tomorrow..By then some other sucker might do it!
online   Reply With Quote
Old 01-21-2011, 03:01 AM   #29
Gasolinedeniz
Gasolinedeniz's Avatar
question was allready answered , so i deleted my post
__________________
Rebel Wire, American Made Harnesess
www.rebelwire.com
Old 01-21-2011, 05:14 AM   #30
Pasta
Newbie
Pasta's Avatar
Go 440
Old 01-21-2011, 07:18 AM   #31
slackcat
Alliance Member
slackcat's Avatar
Running a 273 in my '66 Dart GT, no complaints.
Old 01-29-2011, 09:50 PM   #32
jbtine
Alliance Member
jbtine's Avatar
I just thought of one small problem with running a 273. It's not a big deal if you know about it but if you don't it will bite you in the butt about the time your replacing that automatic transmission with a 68 and later 904 or even an A500. The 67 and earlier cranks had a 40mm center hub that the torque converter fit in. Later cranks have a 46mm hole.
If you go to the later trany you can't use the earlier torque converter because the pump spline count is also different. There may be some some small hub converters that fit the later tranys but how many are available who knows. I rebuilt my Dad's 67 273 Valiant and actuall use a 69 318 crank that way any later trany worked just fine. They use to include a spacer ring with rebuilt converters so the earlier trany could be used behind 68 and later engines. Another solution would be to have the rear of the crank machined to 46mm while rebuilding that 273.
Old 01-30-2011, 09:03 AM   #33
tanof
Grenade Inspector
Doesn't Offy offer an intake for this engine? I see a listing in my old PAW catalog. It is under their custom order section where you have to wait one or two months and once the order is made, it is non-refundable.
Old 01-30-2011, 11:11 AM   #34
OldBlueOval
Grenade Inspector
Thanks for all the info everyone!! I got the 273 with the 904 auto transmission the motor looked clean for it's year. All the linkage and motor mounts came with it . It has the 4 barrel intake and carb, came out of a barracuda 235 horse power turns over adjustable rockers . It was stored inside in a heated garage! The guy I got it from had a valiant 2 barrel set up ,he was going to change his car over to the 4 barrel but had all the papper work on the vailant was for 2 barrel changed his mind. I think if I run headers, new distrubtor, new carb would increase the Hp. will open it up when the weather gets better. Joe
Old 03-08-2011, 02:35 PM   #35
Von Hartmann
Von Hartmann's Avatar
When I was reading my books, I'm pretty sure it said that the 64-65 273s all had solid lifters, then in 66 they offered the hydraulic.
Old 03-08-2011, 02:49 PM   #36
plymouth1952
Senior Member
plymouth1952's Avatar
the real nice thing about a 273 is they had solid lifters ! that means Adj rockers not found on any 318/340/360s. they bolt on any LA motor and work with high lift cams like a chevy would. its also a hard hiting high rev motor like the 327 or 289 were.
Old 03-08-2011, 02:56 PM   #37
Kustom Linez
Kustom Linez's Avatar
I RUN A 273 IN MY UTE WITH SHAVED HEADS & BLOCK, 360 VALVES, AND 340 CAM SHAFT.
THAT EQUALS 7000rpm EVERY DAY AND 140mph. YOU CAN REV THEM ALL DAY AND THEY
SOUND AWESOME!!! ALSO MINE CAME WITH THE STEEL CRANK, THE SAME AS A 340.
In the past, finding affordable pistons for a 273 rebuilt was a challenge. No more. Egge Machine Company has 273 pistons availble in 2 styles, low deck (9:1 compression ratio) and high deck (10.5:1 compression ratio). Prices are reasonable for high compression pistons. www.egge.com .
__________________
WANTED ---SINGLE SIDE OF HEMI EC6 EDELBROCK 6X2 LOG ---
www.chopped.com.au
www.kustomlinez.com
Old 03-08-2011, 03:18 PM   #38
plymouth1952
Senior Member
we must have picks Kustom lines a ute mopar I would like to see this please
Old 03-08-2011, 03:52 PM   #39
Kustom Linez
Quote:
SURE. I HAVE SINCE DITCHED THE CAPS AND RUN BLACK STEELS WHICH LOOKS MUCH BETTER. ONLY PROBLEM I HAVE IS KEEPING TYRES ON THE REAR.
HERE IS THE MOTOR WHEN I FIRST HAD IT IN A COUPE.
__________________
www.chopped.com.au
www.kustomlinez.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
