Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 12-02-2010, 04:15 PM   #1
ANewBeat
Grenade Inspector
ANewBeat's Avatar
Default 52-54 Ford...What to look for?
I am contemplating looking at a 1953 Ford Crestline (less engine/trans) and was wondering if there are any common issues to look out for. Any help is appreciated.
__________________
Adam Cranmer
offline   Reply With Quote
Old 12-02-2010, 04:24 PM   #2
evilkazeevil
evilkazeevil's Avatar
Default Re: 52-54 Ford...What to look for?
Around here it seems they are bad for the inner rockets and floor braces to be completely gone. The gone. The 53 Victoria I'm building for a friend is solid everywhere else bit gone there. I gotta redo all the floor braces and the complete inner rockets on both sides.
Old 12-02-2010, 04:27 PM   #3
daddy_o's_diner
Alliance Member
daddy_o's_diner's Avatar
Check the front crossmember for rust. It's a a common problem, but not a terribly difficult repair
__________________
Follow me on instgram - dpg4410
The Chemical City Coupe
Bonneville inspired '32 ford 5-Window
Build thread
http://www.jalopyjournal.com/forum/s...d.php?t=727871
online   Reply With Quote
Sponsored Links (Register now to hide all advertisements)
Old 12-02-2010, 04:50 PM   #4
ZomBrian
Senior Member
ZomBrian's Avatar
Make sure that the hood is LATCHED!!! If there is an extra hood and hinges (driver side in particular) snatch those up as well. No matter how secure the hood IS, it WILL fly up unless you are expecting it....at all times!
__________________
Having trouble figuring out "how-to"?
Join the Little Pages Tech Archive
Old 12-02-2010, 05:02 PM   #5
loveoftiki
Senior Member
loveoftiki's Avatar
lower front fenders - and everything all the others said.
__________________
Poor Boys Detroit C.C.
Detroit Midnight Mass 2013
Keep Your Flame Lit - RIP Mike Gator Gaydos
Old 12-02-2010, 05:07 PM   #6
Squablow
Old School HAMBer
Squablow's Avatar
Pretty sure that the front crossmember issue is only common to the '54 models, which use a different frame.
The hood hinges like to break, and replacements are expensive, so check the functionality of the hood. What was said about inner rockers and floor supports is very true, heed that info. Take a good look at the roof drip rails too, I've seen a few rot out there and it's a tricky place to repair.
Old 12-02-2010, 05:14 PM   #7
bulletproof1
Senior Member
bulletproof1's Avatar
as stated hood hinges SUCK .parts are kinda high for them and the aftermarket has just stated making some good stuff for them...i put a s10 clip under mine ..was the best thing ive done to it ....
Old 12-02-2010, 08:06 PM   #8
Gretschplayer
FNG
Gretschplayer's Avatar
...all of the above, plus (this could be strictly a problem for cars from the 'rust belt') rear quarters, above the wheel wells. The hood latch return springs get brittle with age, with potentially nasty results, too.
Old 12-02-2010, 09:40 PM   #9
ss34coupe
Alliance Member
ss34coupe's Avatar
I agree with the rust issues - the floor braces and rockers are very vulnerable areas. Make sure you go over the floor both from the top and underneath to get a true idea of its condition. To my knowledge there are no repro floors or braces available - anything I have seen that is advertised as such does not come close to matching the original patterns. I have had to rebuild all the floor braces and replace the floor from the cowl to the rear seat in my 53 Ford convert, a very big job that took several days of work.
Old 12-03-2010, 12:53 AM   #10
JeffB2
Old School HAMBer
JeffB2's Avatar
For plenty of info from those in the know,join the 448 member 1952-56 Ford Owners social group here on the HAMB most of us have "been there,done that" we will be glad to have Ya' come onboard.As far as the hood hinges go,lube them monthly, you can pick up the new reprint of the 1952-54 Ford Service Manual on evilbay for $30,best $30 I have spent.
Old 12-03-2010, 03:51 AM   #11
HOTRODPRIMER
Alliance Member
HOTRODPRIMER's Avatar
Quote:
Good advice Jeff,,HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot
'54 Ranch Wagon build photos
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
