Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#81 |
Old School HAMBer
Here are some tid bits of oil pump info...I have also put this in the OIL System folder.
Dodge started out with what we generally consider to be the '392' pump. Chrysler started out with what is generally called the 'early style' pump. ...and then there is DeSoto... DeSoto used the design of the early pump, but, they used the 'foot' design of the Dodge. So what you have is an early style pump that will bolt on to a Dodge or a 392. Conversely, you can put a new M-50 on your DeSoto, of course the pick-up tube must be dealt with but, hey, were fabricators, right? Also, the DeSoto shaft is about 0.100" shorter than the rest so some fussing is required if you swap things around. 276-291 DeSoto on left, 331 Chrysler on right, note the casting numbers. ![]() The feet sure 'look' the same... ![]() time to get the tape out...DeSoto ![]() 331... ![]() 392... ![]() Hopefully I have been able to offer some additional confusion to the issue.. ![]() Gary
__________________
www.qualityengineeredcomponents.com Early Hemi Parts, Pieces, Tech Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series http://www.discoverthenetworks.org/Articles/Hansen.pdf |
#82 |
Thanks to everyone that have added to this one stop shop for Hemi knowledge. Very impressive. Great work.
#84 |
FNG
I have a early hemi I recently purchased (my first) and the seller described it as a 1958 Dodge 354 Hemi out of a dump truck. I finally got it apart (with alot of patience, 2 cans of PB Blaster and heat,. wheew) and it looks like has never been gone through before.
Headed to the machine shop but wanna make sure I'm on solid ground with the ID. Valley casting number is # 1619829-7 and number stamped on the front of the left bank is VT576. Any help?? Thanks, jeff |
#85 |
Alliance Member
I just want to thank scootermcrad for the wonderful Hemi tech info/index he has provided for everyone who's into Hemi's. It has certainly helped me in quite a few ways. Fantastic work! Thanks, Eric/farmer12
__________________
Mopar or no car GoldChainers CC President Holland Chapter Check out my build thread: http://www.jalopyjournal.com/forum/s...d.php?t=463453 |
#86 | |
Alliance Member
Quote:
#87 | |
Alliance Member
Quote:
Glad the tech helped! I have been SUPER busy around here, so I've fallen behind on the organization of it all. I have a bunch to add, including a BUNCH of info on Daimler Hemis, and some much needed links. In all seriousness, though. This tech is NOTHING without all who have added to it! Keep adding to the tech as you see good links out there! |
#88 |
Alliance Member
http://www.youtube.com/watch?v=bynIPFTZK9Q
Here's the video of its first run. I have already posted this on my build thread a while ago, but I thought you'd enjoy this one.
__________________
#89 | |
Old School HAMBer
Quote:
__________________
#90 |
FNG
Thanks, the link is awesome. I dropped the short block at the machine shop here locally this morning,. I've got the heads that came off of the 354 engine which appear to be truck heads with the "tall" heat passages and second set of 392 passenger heads.
I want to run a 2x2 edmunds intake but the 354 truck heads with the tall heat riser passages in the center arent covered by the intake. In the link you sent me it says the 392 heads will work on the 354 short block but I cant use my edmunds 2x2,. Sigh,. Seems like there should a way,. |
#91 | |
Old School HAMBer
Quote:
__________________
Confucious say Tennis elbow better than Tennis balls |
#92 | |
Old School HAMBer
Quote:
The Edmunds were made for both the small port (51-53) and big port (54) heads. Which do you have? IIRC, all Edmunds have a t-stat so you need to check port size to determine which head matches the intake. You could run the small port intake on large port heads, been done many times, just not the most efficient. You can still use the truck heads, there are two relatively easy solutions, but you will still have water in the manifold: ...Weld a tab onto the intake to cover the port. ...Once the heads have been cleaned, fill the top portion of the port (in the head) with Devcon or something similar. This discussion needs to be moved to a project thread. .
__________________
#93 |
FNG
Thanks for the feedback,. jeff
| Thread Tools | |
| Display Modes | |
