Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 09-29-2010, 05:29 PM   #21
Lobucrod
Alliance Member
Lobucrod's Avatar
Default Re: Cost of Pre-Fab Metal Buildings?
I got a good buddy that will sell you one. Give him a call at 1-800-677-2524. Ask for Bud. He will make you as good a deal on one as anyone can. He's a HAMBer too.
__________________
Just what I need......Another Nailhead!
Makin it Git with Old Shit
offline   Reply With Quote
Old 09-29-2010, 05:43 PM   #22
gravediggers treasures
Alliance Member
gravediggers treasures's Avatar
I bought my metal from plateau metal sales in crossville tn. 800-468-0149 good
people .
Old 09-29-2010, 05:58 PM   #23
73RR
Old School HAMBer
73RR's Avatar
I bought a 45' x 102' x 19' high 'SteelMaster' a few years back. The building delivered was about $22k and the county regs for foundation required 122cy of concrete...your county rules will likely be different...
The same basic building is offered by a dozen different companies that just put their name on the bundle so shop around. On smaller 'steel arch' structures you can gain height by putting the steel on a 2-3-4 ft stemwall, but you'll likely need to get an engineer to stamp the plans.
This building has over 15,000 5/16 bolts holding it together...
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 09-29-2010, 06:06 PM   #24
JOECOOL
Senior Member
JOECOOL's Avatar
If I can remember how to post a pic, here is mine ,just finishing it up now, 24x32 insulated and wired with tube heat, $11,200 all the work done by me.
Click image for larger version
__________________
You laugh at me because I'm different ,
I laugh at you because you are all the same.
Old 09-29-2010, 06:10 PM   #25
hscott
Alliance Member
hscott's Avatar
I built the same, mine was US Building out of Boone,NC; 28x30 for 3400.. You can also buy arches later if you want to add on.
Old 09-29-2010, 06:27 PM   #26
mark boltjes
Alliance Member
mark boltjes's Avatar
I had a 30x50 Cleary building[pole barn] with 11 ft side walls put up 2 years ago and the it cost me $11,600 built on my level site.30x50 5-6"thick concrete floor was about $5000 and the insulation R30 walls and R50 ceiling was another $2000.I bought a real good commercial 16x9 insulated overhead door and opener for $1200. I put a 20 ft Space Ray radiant heater in for about $1600 installed and lined the inside and ceiling with steel strong panel for $1500.Wiring was $750 and the bath room was anther $300-400. All said and done $24,000 a couple weekends and a little help from friends. I should have built it BIGGER !!!
Old 09-29-2010, 08:24 PM   #27
Harrison
Old School HAMBer
Harrison's Avatar
Great info here guys. Thanks so much!
JH
__________________
Yoga Pants & Mini Skirts
Old 09-29-2010, 09:17 PM   #28
4406
4406's Avatar
My 40x60 and 16 foot side walls, my property slopes down so had to bring in alot of dirt. The pad is 40x95 1 14x10 door 2 walk through and one 10x8 and plumming for bathroom $48,500.00
__________________
Misc Odd Parts Assembled Recklessly
Old 09-29-2010, 09:37 PM   #29
Buckster
Grenade Inspector
I was going to build a garage using a prefab steel unit. I found out I was not allowed that type of building in my area. I ended up building a garage with concrete block. Check your local building codes before you get to far into your project.
Old 09-29-2010, 09:41 PM   #30
StinkBug
FNG
I just finished my building about a year ago. 40x40 with 16' side walls. Purchased the building from Empire steel buildings, and have been very happy with them. Got it with full insulation, full interior wall panels, 1 10'x10' roll up door, 1 14'x16' roll up (both insulated), 1 walk in door, 1 3x3 window, 1 3x3 wall vent, and 1 10' roof ridge vent. Total for the building was about $23k
I paid to have the dirt and concrete work done by a friend, which ended up being about $16k total, about $12k in materials. My slab is 6" thick with HUGE footings and a ton of steel, so I'm sure some would come out cheaper, but I wanted to be able to work on anything.
I also paid the same friend to help me assemble the building. It took us some time, but definitely less than it would have taken us to build anything else this size. Almost everything was done by just the 2 of us.
Total cost with everything was around 50-55k I think.
Here's the full gallery of pics of the building construction.
http://s579.photobucket.com/albums/s...%20SFR%20Shop/
Old 09-29-2010, 10:04 PM   #31
Jeff J
Alliance Member
Jeff J's Avatar
Build mine first a 50x60 then had to add on 40 x 100 and it's stick built! Don't want to know what i got in it but it does have a basement and a upstairs mancave ! Took 30 years to save for it and took me a year and a half to build doing most of it myself ! Built the walls 2x6 and insulatation to the hills ! My electric bill last month cooling it was $107.00 and it ran all month here in N.C. been hot and humid !!
ID:	1104145   Click image for larger version
ID:	1104146   Click image for larger version
__________________
If it's not HAMERD then it's to high!!
Now I have a Mercury body again! Ready to Chop ! Turn right no the other Right !!!!
www.jjsrods.com
Old 09-29-2010, 10:16 PM   #32
burnin8
FNG
burnin8's Avatar
Post Re: Cost of Pre-Fab Metal Buildings?
Quote:
That's a helluva nice slice of paradise you've built for yourself!
__________________
Now if you don't mind, I have some evil to tend to.
Old 09-29-2010, 10:20 PM   #33
jbtine
Alliance Member
jbtine's Avatar
I had this built in Ft Worth back in Feburary. It is 40x50 with a 24x40 carport. 12' walls. Turn key price including concrete..$50k
Old 09-29-2010, 10:40 PM   #34
Dave B.
Grenade Inspector
Dave B.'s Avatar
I had this built by Blitz Builders 4 years ago:
It's a custom-design 50'x56' with 12' side walls. It's split 1/3 workshop, 2/3 storage and has 4 overhead doors so you can drive through either side. (This is my second time around at building a garage/shop and I learned the hard way on the first one... the drive-through feature was my first requirement!)
The crew Blitz sent to build it had it finished (less doors) in 3 days! The way they construct their pole buildings is that the site has to be graveled. They build the garage and then you pour the concrete into the floor area, which effectively surrounds the 'poles' in concrete.
I went with Blitz because a friend has one that suffered storm damage and Blitz was super helpful in getting the components to him to make the repair in a matter of days. They also hooked him up with a contractor who made the repairs quickly and did excellent work. It paid off for me because I had a leakage problem with the roof after 2 years. They sent a tech to my site for 2 days, fixed the problem and didn't charge me one cent!!!
The 'kit' was $33k including the price of erecting it. Excluding the cost of the land, I have about $60k in it so far, which includes the prep, building, electric service and concrete (including a huge driveway, which you can't see in the photo because you're looking at the back of the garage) and I figure I have about $15k to go before I'm finished. (I'm slowly doing the wiring, heat/AC and insulation myself).
Old 09-30-2010, 12:21 AM   #35
Alliance Member
Mr48chev's Avatar
Here locally at least, the little nickle paper has a bunch of adds from different builders of these style buildings.
I think that the first thing a guy needs to do is find out what the local building codes allow and require. The prices seem pretty competitive between different builders and sellers here and probably are in most regions of the country right now. You might also keep an eye out for recent shop buildings at other houses in the area and find out who built them and how the owner likes the building.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week.
Old 09-30-2010, 12:32 AM   #36
LIFESTYLZ
Old School HAMBer
LIFESTYLZ's Avatar
Quote:
Originally Posted by J.Fishbeck View Post
Marking this one, like a territorial pissing! Good info here
The Garage Journal
has 100 times more info than what is posted here.
Well worth the trip over there.
Old 09-30-2010, 02:47 PM   #37
Harrison
Old School HAMBer
Harrison's Avatar
Quote:
Originally Posted by Harrison View Post
Yes, I'm aware of the Garage Journal....
Quote:
Originally Posted by LIFESTYLZ View Post
The Garage Journal
This thread has been exactly what I wanted. Many pics, prices, & pointers all in one thread eliminating the need to wade through an entire site dedicated to garages & anything remotely associated with them.
Thanks guys!
__________________
Old 09-30-2010, 03:14 PM   #38
JSanford1974
Newbie
JSanford1974's Avatar
Quote:
Originally Posted by fourforeverfours View Post
I'm about have a final inspection for a 24X40 ft (960 sq.ft. per floor) two story shop. It's an Outback Steel Bldg. which has 12 ga. formed columns, beams and trusses. The purlins and joists are 16 ga. A canister roll up door with opener and high bay lighting fixtures (14' ceiling). Various other amenities and it will cost out at approx. $75k. Please take into account that I did not do any of the work as I'm no longer capable of that type of work. I did shop hard for the bldg.(kit?), concrete/labor and the labor to erect the steel. I was fortunate to have two others to do a lot of the finish and electrical that were either out of work or in the case of the electrician, retired due to an injury. I acted as my own contractor and gopher for those working for me. I had plenty to do as it was.
This is going to be a very good application for me as I'll have a lot of room for a machine shop area, four post lift, compressor on the main floor and an office, storage and wood working area on the second floor. It will service my addiction to Ford AA trucks and keep me out of trouble. It may even provide space for a couple of specalized "retirement businesses".
Would I go with this style of bldg. again, I would say yes. One item that I choose was the high tech insulation. It has a silver side that faces the siding, a core of foam and a white side that faces the interior. That alone was more than I anticipated. It's not the end all, but it certainly has made a big difference when the weather got hot here. On the second floor it helped, but it was still pretty warm up there. W/o it, it would have been really hot. I did think about doing a pole bldg., but having a second floor would not have been as easy as it was with this particular style of metal bldg. A pole bldg. would lend itself to erection by the owner themselves which would save dollars out of pocket, unless one could make more money at their livelyhood with the same time invested building the shop. One must decide that for themselves.
I'm going to attempt to post some photos of the shop so that you'll have an idea as to what I have. If anyone has specific questions, please feel free to PM/E-mail me and I'll do the best I can to answer them.
Outback makes a nice building. I worked with a Outback dealer out of Florida selling for awhile. I got tons of quotes. But people just ain't buying right now.
Building cost has so many variables. You really need to talk with a dealer and work out a quote on what you need/want.
Old 09-30-2010, 06:06 PM   #39
rockable
Alliance Member
rockable's Avatar
I love my Morton building. It's 30X60. It has a wooden frame and metal exterior. They will build it to any stage you want. Since I was traveling and not able to do the work myself, I contracted most of it. They will come out and sit down with you, work up a spec and give you a quote for free. What I like about Morton is that you are dealing with the manufacturer, not some fly by night contractor who might be out of biz in a year or two.
www.mortonbuildings.com
ID:	1104742   Click image for larger version
__________________
You Can't Put A Price Tag On A Good Time!
Here is my 41 Plymouth build thread.
http://www.jalopyjournal.com/forum/showthread.php?t=498434
Old 09-30-2010, 06:27 PM   #40
Hdonlybob
Old School HAMBer
Hdonlybob's Avatar
I was involved with pre fabbed metal buildings for over (40) years, but have been out of it for a while since I retired.
Here are some things to consider on a metal building vs/ pole building.
*Cost will be at least 40% more for a metal building
*Check your local codes. Due to the design of a metal building you need either full footings, or heavy rods across the width to tie the bottom of the frames together.
*Many codes will require full footings and walls for metal buildings
*Pole buildings only require a hole in the ground for main posts. Make sure it is FILLED with concrete. No cookie pads on the bottom.
*Pole buildings can be completed without any concrete. You can do that later, or not at all.
*Metal buildings come in many slopes, as low a 1/4-12 where most pole buildings are either 3-12 or 4-12 pitch, so you could match your house, or other buildings.
*actual clearances in metal buildings is much more, expecially in the middle, as their frames have a sloping bottom, where pole buildings have a flat bottom chord. (Parallel with the floor) making it tough to moung a hoist, etc.
*Many other things to look at, but like I said, both good, but like buying a Hemi, or a
4 cylinder Vega motor.
Send me a private email if you need more info.
Being your in TN, you may not have the zoning/code problems.
Good luck!
Am I against pole buildings....certainly not. I made a good living for many years in sales and project management.
You are talking apples and prunes when comparing to pole buildings, (witch I also sold a bunch of)
Nothing wrong with a pole building, and probably a great deal for a shop.
You can insulate either one sufficiently
Both will have good warantees
Stay away from sliding doors. A pain in the ass and garbage.
Also stay away from the low ballers (Menards, etc.) They are junk.
Do NOT pay more than 10% down, and hold at least 20% back until building is 100% complete. Period.
Butler, Varco Pruden, Star, and several others are all good quality, but you will pay more for Butler and Varco Pruden.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
