Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 12-20-2009, 12:58 PM   #21
MarkL
Grenade Inspector
MarkL's Avatar
Default Re: Any uses for metal bedframes in the garage?
I used some to make bars over the window in my garage, spaced far enough so no one could squeeze between them.
__________________
"Make it three yards mother f*cker and we'll have an automobile race"
offline   Reply With Quote
Old 12-20-2009, 01:40 PM   #22
Shifty Shifterton
Old School HAMBer
Shifty Shifterton's Avatar
Engine dolly. Wheels too. They roll crappy (kinda like a bed) but free is free and I'm not moving engines often. Pretty much one frame equals one dolly. Wheels are somewhat interchangeable if one breaks on ya, or just pop them all out.
__________________
The same........but different
Old 12-20-2009, 01:40 PM   #23
RichG
Old School HAMBer
RichG's Avatar
I've used old bed frames and cheap casters to make mobile bases for saws, tables, whatever in the garage.
Sponsored Links (Register now to hide all advertisements)
Old 12-20-2009, 01:56 PM   #24
Beau
Senior Member
Beau's Avatar
I use them for my Brew Tables! They make a great edge for the tables I make.
You gotta be careful though, some of the frames are bowed. People get rowdy on them things!
EDIT- I have resized the image, but Photobucket is taking a while to kick in.
Old 12-20-2009, 03:53 PM   #25
orange crush
Alliance Member
orange crush's Avatar
I have used a bed frame as a sheet metal brake to bend inner panels for my old chevy. I just clamped them to my deck rail and slid the sheet metal in between them, worked fine. ok so it's kind of red neck. Carlg
__________________
Growing old, not up!
Old 12-20-2009, 04:45 PM   #26
fleetside66
Senior Member
fleetside66's Avatar
I used some to make a stand for my gas tank in the back of my '33 truck, which seconds as a support for the (truck) bed front. It worked out well & the welding was fine. It was an old bed, if that has anything to do with the steel quality.
online   Reply With Quote
Old 12-20-2009, 05:00 PM   #27
Bib Overalls
Alliance Member
Bib Overalls's Avatar
Way back when I was a kid I built a little Briggs and Straton powered go cart out of old bed frames. It was a bitch to cut and drill. The guy who welded it up for me, a pro, told me bed frames were smelted and rolled out of the lowest, cheapest grade of scrap and not suitable for much anything. That was at least 50 years ago and from the above posts it looks like nothing has changed.
__________________
Plan ahead.
Sweat the details.
http://www.flickr.com/photos/ratpoison/
Old 12-20-2009, 05:04 PM   #28
jhnarial
jhnarial's Avatar
The last top I chopped was on a three window 35 Chevy.I didn't have any metal so I used bed frames to cross support the inside of the cab.
__________________
Johnny Arial
http://allmetalshaping.com/index.php
Old 12-20-2009, 05:09 PM   #29
LowKat
Old School HAMBer
LowKat's Avatar
In the early 80's I ended up with the metal from a bunch of 1940's hospital beds.
Here's the sand buggy built from head and footboards.
I sold it but it's still cruising the desert 25 years later.
The angle iron from the beds was tempered to nearly spring steel.
A hacksaw would barely touch it.
Old 12-20-2009, 05:40 PM   #30
Gearhead 10
FNG
Gearhead 10's Avatar
I always save bed frames if possible. Heck its free angle iron! I hacked up a bunk bed frame and made it into a tire rack for my trailer, worked great. People sometimes laugh and say "that looks like a bunkbed" and I can honestly say "yes it is"
Old 12-20-2009, 05:55 PM   #31
rustyford40
Senior Member
rustyford40's Avatar
I have never had a problem welding or drilling old bed rails. I have made BBQ out of them and smokers. And engine dolly's. As with all matels you have to drill at a slow speed. And I weld them with a 6011 rod
Old 12-20-2009, 06:00 PM   #32
nutajunka
Senior Member
Alot of old bed frames have more carbon in them then regular angle, thats way they dull bit's and mess up saw blades. It will flex and return to shape. The only use's I found for it is battery box's and it welds best with an old stick welder. Probally alot more use's though as stated such as cart's. It's free, but harder to work with. I was told used furniture stores will pay 25 dollars for them complete?
Old 12-20-2009, 06:58 PM   #33
Rustys Rod & gun
Grenade Inspector
Rustys Rod & gun's Avatar
Don't use them for any welding projects!There're kinda half ass spring steel and will crack at your weld.If you look at the end brackets you'll see the factory rivits them on.Angle iron isn't worth that much any ways so why bother!
__________________
O.K when I nod my head,you hit it.
Old 12-20-2009, 10:54 PM   #34
low-n-slo54
Senior Member
low-n-slo54's Avatar
I must have some tough ones if they keep my fat ass off the ground everynight.
__________________
Goldchainers C.C./Munsterville Chapter
Breathe if you hate radials.
Old 12-20-2009, 11:03 PM   #35
swimeasy
Senior Member
swimeasy's Avatar
I think that I will keep an eye out for one and then add a box spring and matress and put it in the corner of my shop then, the next time I get the boot, I won't have to go very far!
__________________
"I like old stuff.....That new stuff ain't no good !"(Said to me by an OLD man over thirty years ago)
Old 12-20-2009, 11:06 PM   #36
pasadenahotrod
Old School HAMBer
Bed rails are like spring steel and shouldn't be used for any structural automotive stuff or chassis bracketry ever. Medium duty shelving supports etc. would be fine.
Old 12-21-2009, 12:11 AM   #37
50dodge4x4
Old School HAMBer
I had a "newer" (probably mid 90s stuff) bed frame that I used as braces and such. Cutting and drilling sucked. Then one day I needed a short 2" long angle bent at about 80 degrees instead of 90. I clamped a piece of bed rail in my vice and gave it a whack with the hammer and it BROKE!. I don't even keep the stuff around anymore, the quality is just too inconsistant. Gene
Old 12-21-2009, 07:54 AM   #38
bobss396
Old School HAMBer
bobss396's Avatar
I've used them on stock cars for non-structural details like battery boxes, fender supports, radiator mounting, etc. It always had welded well enough for my use.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
Old 12-21-2009, 07:59 AM   #39
29nash
Excellent for structural, after all that's what they are...... Do a rockwell if you doubt the tensile strength. Weld with OA, difficult to drill holes in it, dulls a normal drill bit quickly.
Old 03-15-2010, 10:50 AM   #40
Fordguy321
Fordguy321's Avatar
bed frames are bad ass! people throw away good frames! good peices to make carts, stands , shelves. jigs. etc. and sometimes u get good wheels!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
