Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 11-03-2009, 04:41 PM   #1
roadstar
Old School HAMBer
roadstar's Avatar
Default I need to see an original 32 Roadster dash
I have a flat dash from Brookville for my new roadster and it doesn't even have the hole for the gauges. But I think there is more to it than just an oval hole.
The original sedan I got the firewall and gauge tunnel out of had a reveal around the oval dash opening that went inward, and a stainless ring the goes on the edge.
My question is does the roadster have the same opening around the gauges as the sedan and coupe.
I searched for 32 dash pics and cant find much more that streat rod dashes with aftermarket gauges and billet bezels or s/w panels.
So I was hoping to get a good look at a stock 32 Roadster dash.
Thanks
offline   Reply With Quote
Old 11-03-2009, 04:56 PM   #2
bluardun
FNG
Default Re: I need to see an original 32 Roadster dash
You're right on about the oval flared inward with a stainless ring. Ford only made one instrument panel. The tunnel type. As you know, the roadsters and pheatons have a different dash panel that the coupes and sedans, but the center area looked alike.
You might contact the guys at Vintage Ford in Phoenix. They have a customer that has dyes to stamp this flare in a flat Brookville dash.
Best of luck
Old 11-03-2009, 05:09 PM   #3
roadstar
Old School HAMBer
roadstar's Avatar
Quote:
Best of luck
Thats great do you have a website or number.
I thought of cutting the center out of sedan or coupe dash since they are much easier to find but stamping the flare in would be the way to go.
Thanks for the info.
Old 11-03-2009, 05:41 PM   #4
Deuce Roadster
Old School HAMBer
Deuce Roadster's Avatar
Ask and ye shall recieve
All the 32 passenger vehicles had a oval panel in the center of the dash. All the passenger cars also had a small stainless trim ring around the edge of the dash opening. Both of mine have been modified with the addition of aftermarket gauges ... but the SS panel is correct.
The SS panels are now available in repro ( blank - no holes ) so you can put the gauges where you want.
Randy
__________________
http://www.jalopyjournal.com/forum/s...ead.php?t=5877
F-100 brake Tech
Old 11-03-2009, 05:55 PM   #5
roadstar
Old School HAMBer
roadstar's Avatar
Thanks for the nice closeup of your roadster dash, and great job on that 3 window.
Old 11-03-2009, 06:15 PM   #6
pprather
Newbie
pprather's Avatar
Did a search on "Vintage Ford in Phoenix" as Bluardun suggested. Came up with this:
http://www.so-cal-az.com/Contact_Us.html
Hope they can help with the dash punch.
Old 11-04-2009, 10:03 AM   #7
Bruce Lancaster
Alliance Member
I have a brookville dash and with it a chunk of real '32 dash with the recess...this piece was crudely hacked out of a restored car by streetrodders, wild cutoff wheel slashes all around. The pitiful fragment is still perfectly woodgrained....
__________________
Bruce
Old 11-04-2009, 10:18 AM   #8
tommy
Old School HAMBer
tommy's Avatar
I have a gennie on the shelf if you need close up detail shots. Let me know what you need.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 11-04-2009, 10:43 AM   #9
roadstar
Old School HAMBer
roadstar's Avatar
Quote:
Well hey if your not gonna use it.....
Actually if I had a wood buck I think I could beat the opening in, I have the stainless ring already.
Old 11-04-2009, 11:23 AM   #10
MilesM
Alliance Member
MilesM's Avatar
Frank Borowitz, Premier Frame and Body (602) 248-0812 has the Dick Smith dies. He can stamp Roadster dashes with or without the center hole.
He makes alot of other Deuce stampings like the side curtain support rod hole and others.
Old 11-04-2009, 12:35 PM   #11
roadstar
Old School HAMBer
roadstar's Avatar
Thanks Miles, got your pm too, This car does have the side curtian hole added to the right door only, I assume they would have been on both doors,, I might have to get one for the drivers side as well, or maybe both, because it looks like a biginner welding student put the one on the right door anyway.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
