Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-10-2009, 09:48 AM   #1
RacerRick
Old School HAMBer
RacerRick's Avatar
Default What are the differences between a 55' 2 dr wagon and a Nomad?
I have a 55' Handyman parts car with a good title and have been talking to a guy with a 55' Nomad that is rough, and has no front sheetmetal, and no tags or title. The handyman has no frame left and the nomad has a good frame.
What parts are nomad specific and would need to be used to convert the 55' wagon to a nomad?
offline   Reply With Quote
Old 06-10-2009, 09:52 AM   #2
416Ford
416Ford's Avatar
Default Re: What are the differences between a 55' 2 dr wagon and a Nomad?
For starters, the roof, back glass(sides) and tailgate. The door glass if different to I believe.
__________________
My 46 Ford Build
Old 06-10-2009, 09:55 AM   #3
thebigdaddyo
Alliance Member
thebigdaddyo's Avatar
The B-pillars and the doors (handyman doors are sedan and the nomad is a hard-top style
Sponsored Links (Register now to hide all advertisements)
Old 06-10-2009, 09:58 AM   #4
buckeye_01
Senior Member
buckeye_01's Avatar
Converting a handyman to a nomad? Whew! Doors, roof, tailgate and quarters.
__________________
-Jon
Old 06-10-2009, 10:00 AM   #5
54BOMB
Alliance Member
54BOMB's Avatar
Quote:
Yep, the slant in the B pillars is the dead giveaway
Old 06-10-2009, 10:03 AM   #6
49ratfink
Old School HAMBer
49ratfink's Avatar
doesn't the Nomad have the shorter "hardtop" windshield?
Old 06-10-2009, 10:06 AM   #7
2002p51
Alliance Member
2002p51's Avatar
Quote:
That's correct. The Nomad has a lower roofline than a standard wagon. Uses the same windshield as the hardtops and converts.
__________________
Still crazy after all these years.
Old 06-10-2009, 10:08 AM   #8
Krash Vegas
Grenade Inspector
Krash Vegas's Avatar
I think the front sheet metal is the only thing they have in comon.
__________________
Be sure to eat your Rockabilly O's!
http://www.youtube.com/watch?v=Y1Gno_JOxbI
Old 06-10-2009, 10:12 AM   #9
McKee
Senior Member
McKee's Avatar
Blue car is a Nomad,...Yellow car is a 2 Door Wagon.
Click image for larger version
ID:	681119   Click image for larger version
ID:	681120   Click image for larger version
Old 06-10-2009, 10:17 AM   #10
Stick004
Grenade Inspector
That's awesome. I had always wondered that myself. Thanks for the pics McKee!
Old 06-10-2009, 10:19 AM   #11
RacerRick
Old School HAMBer
RacerRick's Avatar
I can get a nomad that has a complete body tub with all the doors, glass, and trim on a good frame but no tags or title. The car is rough but comes with new quarters, 1 piece floor, etc
I have a badly rotted 55' handyman that is only good for parts but has a good title. I was going to use the remains of the nomad to convert the handyman. The VIN will still say 6cyl handyman obviously.
Old 06-10-2009, 10:20 AM   #12
jonzcustomshop
Senior Member
jonzcustomshop's Avatar
except for the floor, cowl and dash, nothing is the same the front sheet metal and frame will interchange.
your best bet is to cut every part of the handyman off, basicly ,leave about a 1/2 inch of the handyman around the vin tag. then cut the exact opposite of the way you cut the handyman on the nomad, weld the 2 together, and you are done!
the main issue this will give you, is that your vin will reflect a 210, or 150, as the handymans were not belairs, and the nomads were.
All kidding aside, the handyman will be a good parts car for the nomad, do some research, and see if you can get a bill of sale from the guy for the nomad, and then go through all the bureaucratic channels in your state to get a vin assigned to it.
**** hint,hint*****
the original nomad vin # is stamped on the top of the left hand frame rail under the drivers seat area!
just be careful, because that vin is probably somewhere in the us (or canada)on another nomad that has your missing vin plate and cowl tag.
Old 06-10-2009, 10:30 AM   #13
Geeto67
FNG
the way I see it use the handyman as a body panel and vin tag donor for the nomad. If it needs quarters and floors cut and weld them in off the handyman - it sounds like more work than an entire roof/windshield transplant but really it is probably about the same. I am pretty sure you cannot tell anything about wether the car is originally a nomad or not and I don't think there were any trim tags for 1957 Chevys (not that it matters much - most states you don't need a title to register a vehcile that old so if you have a vin number you may still be able to get paperwork).
edit: I take that back you can tell the model from the vin but I don't think nomad had a special letter in the vin number like 150, 210s, and Sedan Deliverys do. Also the Passenger cars had cowl tags, the corvettes didn't so I am double wrong.
Old 06-10-2009, 10:44 AM   #14
paperdog
Alliance Member
paperdog's Avatar
sound like this will end up as "el camino' type roadster pick up
pleeze do it and get one more nomad cut up so they're value stays where it is !
__________________
Anything is possible if you don't know what you are talking about.....
online   Reply With Quote
Old 06-10-2009, 11:13 AM   #15
Django
Old School HAMBer
Django's Avatar
Quote:
The wheel wells and probably the whole quarter panel is different.
You could try doing a VIN search to see if that number comes up as someone else's car. If it does, then go for it. You could always find a Nomad title too.
Old 06-10-2009, 11:35 AM   #16
Nomad
FNG
There was also Nomad-specific front fender trim and chrome headlight eyebrows on the '55s. I don't think the actual fenders are different, but the trim is. I believe the trim is repoped, but not cheap. Of course, you could always leave the trim off as a "custom" touch...
Old 06-10-2009, 11:44 AM   #17
56sedandelivery
Senior Member
Well now, here's what I'd do. It sounds like the "Nomad" is in better condition, and as such, easier to redo using the "Handyman" wagon for parts. Even use the VIN tag and title from the "Handyman". Most people, who don't really know their classic Chevrolets, call a 2 door wagon a Nomad; here's a case where you can call your "Nomad" a "Handyman" or 2 door wagon. Or go through a title service to make the "Nomad" legal. Personally, I really don't care too much for "Nomads", I like things Plain Jane. But, in your case, go with the "Nomad". Butch/56sedandelivery.
Old 06-10-2009, 12:21 PM   #18
panic
I would guess that the same differences apply to Safari vs. sedan-based 2-door wagons (although it appears that the Safari name was used on more than 1 body style)?
Old 06-10-2009, 12:28 PM   #19
loburban
Grenade Inspector
Call Rods n Resto's in Centre, Al. they just collected abunch to build a nomad out of a handyman.
Old 06-10-2009, 12:57 PM   #20
rixrex
Senior Member
What they said, it would be alot of work..notice that on the Handyman wagon the tailgate/ass end section of the car is more vertical..the Nomad section is laid forward a bit more..Go for it! almost nothing cooler than a Nomad...
__________________
Why Sir, you are drunk!...Yes Madam, quite drunk..and you are ugly, However, In the morning I shall be sober...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
