Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-26-2008, 08:34 PM   #1
micro
Newbie
Default 54 Pontiac Flat Head 6 performance build
Has anyone done a performance build on a 54 Pontiac flathead 6, whom would make the headers, intake, dist, what piston combo, would I be able to stroke this motor, and whom makes a custom ground cam for this. An finally is the bell housing part of the motor, or can I remove this and convert it to a 700r4 or a gluide.
Tom
tct546@yahoo.com
offline   Reply With Quote
Old 10-26-2008, 08:55 PM   #2
55chieftain
Senior Member
55chieftain's Avatar
Default Re: 54 Pontiac Flat Head 6 performance build
You can remove the bellhousing and get a conversion kit from bendtsens, the bellhousing is the same as the st-8.
Heres the response I got last time I asked this question, and also the cam info. You can get it if you want, I'd just be happy to get mine going at this point.
http://www.jalopyjournal.com/forum/s...ad+performance
__________________
Vintage Drag Meet
Meltdown Drags-Byron Il
July 18, 19 & 20 2014
Old 10-26-2008, 09:20 PM   #3
micro
Newbie
Thanks for the info
Sponsored Links (Register now to hide all advertisements)
Old 10-26-2008, 10:30 PM   #4
HEATHEN
Old School HAMBer
Edmunds made a head and dual intake (good luck finding either), and Mallory made a dual point distributor.
Old 10-26-2008, 10:46 PM   #5
Zig Zag Wanderer
Zig Zag Wanderer's Avatar
HAMBer Bumpstick posed a similar question in the straight 6 thread; i'll repost my response here, adding a few bits and leaving out the cam advice, which you have well in hand. the cam that Vintakes has sounds perfect!
there is SOME degree to which this engine has been hot-rodded. Eddie Miller also used one in his early '50's open-wheel streamliner.... this information is paraphrased and lifted from "How To Hotrod Your Car" by the editors of HRM (Wally Parks, Don Francisco and Racer Brown) c.1952 by Trend Books.
the blocks are stout, and thick-walled. the stock 3 9/16" bore on the 239 six can be bored .187 to 3.75" without sonic check. that gives 265 cubes with the stock stroke of 4". these have insert mains and rods and a good full pressure oiling system. the book recommends line boring the main saddles and line honing the inserts to size. (think about purchasing slightly undersize bearings and having the journals hard-chromed back to standard spec to accomplish this). the crank and rods are forged and hella stout, in fact the rods used to be much sought after in the Model B/C Ford crowd for use in those engines. also, in fact, the best approach to building this engine is to think of it as a 6-cylinder version of a Model B/C Ford, with a skirted block, already converted to full pressure and inserts, that you can get absolutely no speed equipment for; you will have to make or adapt everything.
the book says to discard the 2-pc wristpin bushing and use a bushing that has a .060" heavier wall thickness, requiring boring the small end, but does not state a source application...it says also to use 1938 Dodge truck wristpins (any of you Mopar flat-six guys got a diameter on those?)
the stock pistons are cast iron. six of your best friends who are smokers just got new ashtrays....don't know about compression height but there are a lot of engines out there built in the last 50 years with around a 3.75" bore. something off the shelf might work.
valves up to 2" can be fitted without head gasket interference; and should be as the stockers are too small to make power. the block should be relieved 1/8". the stepped area over the exhaust valve should be flycut an equal amount to the amount the head is milled, of which .183" is the maximum cut. a combo of filling the chambers with weld and milling should be the plan with a flat-top piston, probably best zero decked with a very slight flycut above the bore after filling. sparkplug location is poor, limiting your compression to 8 to 1 without detonation.
Edmunds did make a dual-carb, but it has to be hens-teeth by now. if overbored to 265 the engine could end up needing more carburetion than the Edmunds could provide anyway.
make your headers, copy what works on A/B/C Fords as far as primary length and diameter.
an intake could be easily made in the log style, think about a 4-carb built for stromberg 81's patterned after the Howard's 5-carb GMC 6 style.
ignition; all the book says to do is consider a magneto....may still be the best advice. i'm sure a base will have to be adapted by now. if you use a vertex make sure it's advance curve is not locked out for racing. any mag shop can unlock, recurve and test the unit economically and it's money well spent.
Dyna-Flyte offered a dual-point breaker plate to convert the original Delco distributor using Delco d103 points. a good, properly set up dual point with a big old Mallory Voltmaster and an MSD-6 under the dash is still a pretty serious ignition and nothing to sneeze at.
lighten the flywheel, or step right up for a custom aluminum one...
__________________
Old 10-26-2008, 10:54 PM   #6
panic
It's a great idea.
Everyone makes speed equipment for that engine, just go down to Walmart and pick them right off the wall.
Open the package, and they install themselves.
Instant 500 hp.
Old 10-26-2008, 11:37 PM   #7
Zig Zag Wanderer
christ panic, here we go again.
__________________
Old 10-27-2008, 08:05 AM   #8
RichFox
Alliance Member
RichFox's Avatar
Eddie Millers engine
Click image for larger version
Old 10-27-2008, 09:42 AM   #9
Bob the Ferret
Bob the Ferret's Avatar
Location: Santa Rosa NM Yes, it's part of the United States
Quote:
Originally Posted by panic View Post
It's a great idea.
Instant 500 hp.
Wow !!! Who knew that Wal Mart even carried that stuff ?
__________________
Holy Bullet Nose Batman !!! That's a Studebaker !!
Old 10-27-2008, 12:20 PM   #10
panic
I'm really confused.
When someone who appears (to me, but my perspective is 45 years of involvement) to be someone who wants to do something himself (Yay!! always good), but has picked an obscure and (my opinion) not especially good candidate for a subject.
I don't want him to buy a crate motor. I don't want him to do what everyone else does.
I want him to understand exactly how difficult this will be, given the lack of aftermarket stuff, and the scarcity of information.
I also suspect that he will be disappointed in the end result, in how long it will take, how much it will cost, how much work simply must be fabricated (by whom?), and how much power results.
Is he still set on doing this if it takes 2-3 years, costs $3,000 above the cost of rebuilding the motor, and results in 150 hp (far more than stock, but not what I would call sparkling given a heavy car)?
An example of $$$: "the book recommends line boring the main saddles and line honing the inserts to size." Except the 4 main journals are 4 different sizes. That means 4 passes, done in order.
The stroke is not bad for such an old design, 4" (same as BBC 454) gives a mean piston speed of 3,500 f/m (pretty safe for a quality piston) at 5,250 RPM. Based on probably having long rods (common practice then), the max RPM @ 80,000 f/s/s is about 5,800.
I'm not sure the huge bore sizes popular "in the day" were a good choice, since they were based on the "if you can't see through it, and it doesn't leak - run it" method. Even up through the 1960s, Jenkins was yelling "yes, you got an extra 3" out of it, but you have no ring seal!!!". I'm pretty sure +1/8" (.125") is safe, and perhaps 5/32" (.156").
Pistons with flat tops in 3-11/16" (+1/8", or 3.6875") include 325" Dodge poly, 273" LA (oversize), late Ford 6 200/250 (oversize).
The engine does have a big advantage (based on the LSR photo): individual exhaust ports. This means that joining the 1-2-3 and 4-5-6 is as effective as it would be on a Supra today - a long tuned header will work very well, but it will be a pain to fab and fit to the car. Primary tube: no more than 1/8" larger than the port ID.
The intake should be made, not only because an original is going to be $$ but we know more now than they did (no one would use what we see on that race engine today). This isn't hard to do; the obvious choice is 1 progressive 2 bbl. on each group of cylinders front and rear. You need about 150-200 CFM per carb, but progressive gives better mileage and response.
A log is easier to build but IMHO won't provide the same idle quality or mixture distribution.
Old 10-27-2008, 12:27 PM   #11
shpotty
Grenade Inspector
shpotty's Avatar
They switched to aluminum pistons in the six for '53 and '54. The eights had iron pistons the whole production run.
__________________
Bart (They call me Daddy at home.)
"Knowledge without imagination is nothing"
Albert Einstein
Old 10-27-2008, 06:48 PM   #12
panic
The Pontiac appears to be (what the British would call) a "10 port" motor: 4 intakes + 6 exhausts (like the Ford 223), which was quite advanced compared to the more common "7 port" (3 intake + 4 exhaust) found in other inline 6s like the 235, GMC.
A Ford 223 intake manifold (although too short front to back) may be close enough to modify by splitting into a front and rear section, rather than a complete fabrication.
Old 10-27-2008, 07:29 PM   #13
55chieftain
Senior Member
Did you get to check to see if your head was stamped "high compression"? One advantage of it being a 54 over earlier years it has the bigger 2bbl already on the intake. If you can stand looking at one carb for now anyway.
__________________
Vintage Drag Meet
Old 10-27-2008, 09:23 PM   #14
panic
I agree - if you have a big 2 bbl. now, work on the other stuff to conserve the budget. It will run just fine with only a jet change when complete, and this will bring completion forward in time with only some peak power missing.
Since you have 6 exhaust ports, you may be able to salvage a header from another small 6, such as the Ford 170/200 just to jet the flange & primaries, then mod the lower half to suit the car.
Do you know the size and shape of the intake ports?
As was said, a bigger intake valve is a major help (at reasonable cost). If you can measure a dead original I can dig up some possible swaps. This kind of mod must be in the original plan, because it affects your chamber shape, final compression ratio, valve relief contour, and cam choice.
Here's a generic SV chamber with "Somender Singh" style grooves, which IMHO are worth doing.
Depending on where the water is, it may be possible to re-locate the plug. At the exhaust valve is preferred, but may not be possible.
Old 10-28-2008, 05:06 AM   #15
unclechop
Grenade Inspector
unclechop's Avatar
Ive got the head off at the moment I will measure the valves(pics any one?) tommorrow.
I had the head shaved 0.040 (It needed that to clean up)
Should I open the combustion chamber a little?
I might measure the volume and work out comp ratio(dont want ping)
Apparantly ive been told not to use extended electrode plugs
could that also cause pinging??
Old 10-28-2008, 07:53 AM   #16
panic
To do what?
Pinging in a flathead motor has one basic cause: too much squish clearance.
Never heard that.
Old 10-28-2008, 09:12 AM   #17
Hudsonator
Grenade Inspector
Hudsonator's Avatar
That head example looks suspiciously like a Hudson. I have a friend in Texas that swears by the Somender Singh groove and performs the operation on his Hudsons.
Rudy does good work, I believe that is his cylinder head in the picture.
Good info Panic, keep these boys on thier toes.
Hud
__________________
Hudson Super Six Engines
The King of Flatheads....
was not built by Ford
Old 10-28-2008, 07:43 PM   #18
55chieftain
Senior Member
Here's what the 239 head looks like in the first pic, second is the 2 carb intake(small pic), 3rd is the 54 Bonneville st-8 with the Zenith sidedraft carbs, always wanted to build a 6 cyl version, last is mine although more together at this point in duplicolor racing green
ID:	523278   Click image for larger version
ID:	523279   Click image for larger version
__________________
Vintage Drag Meet
Old 10-28-2008, 08:16 PM   #19
panic
That chamber looks very good compared to some older stuff. Note the angled "shelf" masking off the exhaust valve relief - allowing a more direct path from the intake relief (with the plug hole) to the bore. This also reduces chamber volume, allowing more compression without restricting breathing.
The reliefs can be improved with a bit of die grinder work, but you have to have the final valve sizes set & seated first.
That manifold is also pretty good. It could be modified (permanently, I'm afraid) without too much work to greatly improve peak power even with the original carbs. It could also be sacrificed as the donor for a more complex manifold - saves a lot of fabrication.
Looks like good things can be done - if this is what you want...?
Old 10-28-2008, 08:43 PM   #20
55chieftain
Senior Member
I love the way these sound , a little more work and mine will be running in the 41
http://www.youtube.com/watch?v=VGIE0...eature=related
__________________
Vintage Drag Meet
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
