Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 01-09-2008, 03:26 AM   #1
Gaters
Grenade Inspector
Gaters's Avatar
Default Miracle Makeover - Part 2
A lot of responses to my first post asked that I keep them up-to-date on the build. So this is my second posting regarding my roadster, it's history with my family and my Pop.
Here is the link to my original post in case you want to read this first. If you haven't read this first, some of the references I make in tis will be tied to what I've already described or explained in the first post.
http://www.jalopyjournal.com/forum/s...d.php?t=232944
I have posted more pictures of the original fabrication Ray did to the roadster as well in part 2.
To other HAMBers that might have any information about the South Gate Gaters, please contact me. Cyclone Kevin let me know his Uncle grew up in Maywood/South Gate and was a Gater back in the day. Hopefully I'll hear and learn more from Kevin, cool stuff.
So one of the cool stories my Pop tells me about going out to El Mirage was when he'd sit in the roadster next to Ray. One of his jobs as a passenger was to keep Ray from getting a ticket driving through town. Since the race headers would be attached/uncorked and would stretched just past the passenger-side door, my dad would carry a coffe can to place over the end of the header in case cops came into their line of site. Apperently this would help quite the sound of the exhaust enough to sneak by. HA!
Dismantling the Roadster
As I disassembled the roadster, there were a number of fabrication alterations that I shared in my last post. Here are a few more interesting finds.
Somewhere in here is the original steering hole mount. Since the steering box was changed from the original A box (to a 1932-34 steering box identified by other HAMBers, thank you) the steering column had to be adjusted to mount under the Auburn dash. After speaking with a few ol' time lakesters, placing a few slotted mounting holes helped locate the steering column to its new position. You think Chip Foose would do this on a clients build?? Heh!
I posted more detailed pictures of how Ray attached the 32 center Xmember. I get a kick out of how they welded this into place. OK, so what's with the saw tooth edge on the k-member? What did they use, drill holes to seperate it?
Top shot of the welds on the Xmember. Unfortunately, I never learned to weld but I do know a good weld when I see one. Ehhh...this one got the job done...and it did hold together going 115.97mph and had lasted over 60+ years...I'd say it passes.
I posted a picture of the split wishbone bracket on the passenger side last time. Here is a picture of the drivers side. Same nice textured bracket on the other side but I haven't figured out what the small bracket just to the left is for. If you look close at the frame, just behind and above the bolt on the bracket there is a vertical weld in the frame. I found out that the frame had been repaired where it split. Hmmm...take a look a the next photo.
In the C-channel of the frame I found this L-shaped piece of steel bolted on the inside to support the structure of the frame and the weld on the outside. This repair is right under you ass when you sit in the car. Ahhh...the thrill of it all!
One thing I learned from the removal of the rearend and spring was that, if you remove leaves from the springs to lower the car, you need to fill the gap where the leaves once were. Case in point, weld filler pieces into the U-Bolts that hold the spring to the frame. Notice the one on the left has two pieces...yeah...the bottom piece of steel is a bolt with the head cut off, can you see the threads?
Here is another entry from the original SCTA program that has information about my roadster. Look at the Gaters section and you'll notice the Ray Pyle info and my roadster. You'll also notice the penned information about Regg Schlemmer and Emil Dietrich both Gaters. Regg actually tied in the individual point championship in 1947 I beleive. His T Roadster graced the first cover of Hot Rod magazine. If you haven't seen this already, a knock off of this roadster way built to commemerate Hot Rod's magazine's anniversary.
http://www.hotrod.com/projectbuild/1...car/index.html
Ray Pyle
Unfortunately, I don't remember Ray. He passed away in the mid 1980's. He moved out to Lancaster, CA which was pretty much desert when he was out there. After he passed, my dad asked his daughter if her dad still had any car parts at his home. She didn't know but allowed us to go look if we wished. My dad and I drove out there one afternoon. He lived out in the middle of nowhere. It was a small one or two bedroom home with a car port but no garage. An old 60's truck sat in the drive way. We went around back and poked through an old shed. There sat an old B-block with a hole in it where a rod had shot through. This was at least promising that car parts where at the location. I don't recall what it was but we'd noticed a car part sticking half way out of the shrubs and desert sand. We then noticed these small piles of sand and shrubs all around the yard. We started poking the sand with stick to see if we'd hit anything. I didn't know it time but we struck gold. There we found the 2-Port Riley Head that ran in the roadster. My dad remebers that Ray ran a Riley head and that it had been cracked. We checked it and it was still cracked. I hate to tell the rest of the story because some time later, 2 or 3 years down the road, we sold the Riley head. Even though it was cracked, I cannot believe we sold the dog-gone thing. UUGH!! Now I feel depressed. There is more to this story on how and who cracked this head that I will reveal in a later story.
More about Ray. He was a true American hero. He was fortunate to have survived the WWII, coming home with a purple heart. During WWII he served as a belt-gunner in a B-17 bomber. From all accounts that I've learned, this was a very high risk job.
He served in Ridgewell, England in the Eurpoean campaign. This an aerial map of the landing strip in which he was stationed.
He was in the 381st Bomber group, 534th squadron. These are the inginia for the group and squadron he served. I'd like to incorporate the Squadron Dragon into my car somehow. I haven't decided what I might do. I'll take any suggestions.
This is a picture of "The Fox" the ship he flew the most missions.
This is a list created bt Ray of all the "ships" he flew in during WWII.
Here is a picture of Ray at his shop/gas station. It looks like he was salvaging inner tubes. His daughter Linda told me he didn't much like having his picture taken. This shot looks like the photographer knew this and caught him off guard. Can you identify the convertible in the background?
I've got my roadster nearly cleaned up and ready for assembly. I'll wait a few more weeks to post another segment on the progress of my roadster so that I have some thing to show for. I'll also reveal the story behind the cracked head.
Stay-tuned,
Chris
__________________
Diplomacy is the art of saying 'Nice doggie' until you can find a rock.
-WILL ROGERS
offline   Reply With Quote
Old 01-09-2008, 04:00 AM   #2
Jimmy B
Alliance Member
Jimmy B's Avatar
Default Re: Miracle Makeover - Part 2
Chris, thanks for the update and more history on the roadster.
Cheers
Jimmy
__________________
jimmybarter.com
Old 01-09-2008, 04:06 AM   #3
29bowtie
Alliance Member
29bowtie's Avatar
Thanks for the further history of this interesting time. You are now the "caretaker" of an important historical auto. I wish you all the best in the preservation.
__________________
SURGEON GENERAL WARNING:Hot Rodding is hazardous to your wealth!
Old 01-09-2008, 04:51 AM   #4
Omega
Omega's Avatar
This is amazing! Thanks for sharing.. I hope you can get the riley head back! althought i doubt it.. but hey..the HAMB has done wonders in the past!
Old 01-09-2008, 06:41 AM   #5
Cajun Kenny
Alliance Member
Cajun Kenny's Avatar
Location: Just Another Smart Ass White Boy In Mississippi..
cool story and history .. thanks for the update..
__________________
When The Shit hits The Fan It Will Not Be Evenly Distributed!
The Douche Formerly Know As flh4speed!
online   Reply With Quote
Old 01-09-2008, 06:51 AM   #6
SUHRsc
Alliance Member
SUHRsc's Avatar
Zach
__________________
WTB pre1950 Harley Davidson
38-39 Lincoln bumper guards
Old 01-09-2008, 05:58 PM   #7
THOMAS S&C
Grenade Inspector
THOMAS S&C's Avatar
Thanks, very cool story and pics. I had to do the same thing to my U-bolts on the rear of my car, I did a little cleaner job of it though!
__________________
Formerly known as ME-OHs S&C
Jeremiah
FLYERS CC
FLYERS Roadster Club
www.myspace.com/flyerscc
Old 01-09-2008, 06:13 PM   #8
mazdaslam
Alliance Member
mazdaslam's Avatar
Those "saw tooth cuts" look like a series of close spaced drilled holes were used to "cut" the crossmember out of the 32. Way cool project you got there.Please try to preserve as much of it's original character as possible.
__________________
"MONSTERFLAKE"Kicks ASS!!!
50 Merc.....ON THE ROAD!!!
40 Merc,NEXT!Thanks Clark !!
Old 01-09-2008, 06:15 PM   #9
rustybucket
Alliance Member
rustybucket's Avatar
Thanks for the update. Very well organized post, the way they all should be. Can’t wait for part 3.
Chris
__________________
FLYERS CC
Old 01-12-2008, 05:40 PM   #10
AV8-Rider
Alliance Member
AV8-Rider's Avatar
I enjoy this.
Paul
__________________
Sarpsborg Hot Rod Klubb
Old 01-14-2008, 07:31 AM   #11
Omega
Omega's Avatar
Alot of folks missed this thread...heres a bump for you..because this car deserves attention
Old 01-14-2008, 08:49 AM   #12
Big T
Grenade Inspector
Big T's Avatar
Great post... I noticed there were 34 missions listed, but not a 35th. Early in the WWII air campaign, crews had to fly 25 missions. Then it was bumped to 30 and eventually 35. I assume Ray was flying during the time 35 missions had to be flown and he just didnt enter the name of his final plane.
Love the story of the car and the background information is awesome. Keep the posts and pictures coming.
__________________
Vintage isn't cool, if it doesn't work.
Old 01-14-2008, 08:59 AM   #13
flt-blk
Old School HAMBer
flt-blk's Avatar
Isn't the 35th mission the ride home?
__________________
THEM TX "Nomad"
Old 02-08-2008, 05:38 AM   #14
Mercmad
Senior Member
He got a purple heart so there is every chance he missed his final mission due to injury. Thank goodness for people like him!
Old 04-20-2009, 01:37 PM   #15
303racer
Alliance Member
303racer's Avatar
any updates on this car this was a great thread
__________________
"Success usually comes to those who are too busy to be looking for it"
Old 09-14-2009, 11:11 AM   #16
Bullet Nose
Bullet Nose's Avatar
Quote:
Originally Posted by Gaters View Post
Here is a picture of Ray at his shop/gas station. Can you identify the convertible in the background?
I've got my roadster nearly cleaned up and ready for assembly. I'll wait a few more weeks to post another segment on the progress.
Hey Chris ......
I ran across this old post and wondered how you were coming along with your car. Maybe I've missed some of your other "update" posts.
I think that car in the background is a 47 or so Buick.
I really enjoyed reading about Ray.
Bill
__________________
"REAL lowered cars don't have air bags or hydraulics!"
Old 09-14-2009, 11:32 AM   #17
Django
Alliance Member
Django's Avatar
Pretty cool.
You could get an A-2 jacket and put The Fox noseart on the back and the squadron patch on the front.
Old 10-02-2009, 03:11 AM   #18
Gaters
Grenade Inspector
Gaters's Avatar
Quote:
Originally Posted by Bullet Nose View Post
Hey Chris ......
Bill
Bill,
A couple of cool events have taken place since this last post. Go to the last link first to see the ride of my life with my Dad in the drivers seat.
http://www.jalopyjournal.com/forum/s...racle+makeover
http://www.jalopyjournal.com/forum/s...ht=crewl+world
My last ride has been the Father's Day LA Roadster Show with my Pop. We had a great time there too. I have a bitter gas tank that's keeping me off the road. I gotta get back to it so I can drive it and take it out locally. I miss driving it around.
Chris
__________________
-WILL ROGERS
Old 10-02-2009, 03:41 AM   #19
RAY With
Alliance Member
RAY With's Avatar
What a story and piece of history. Chris I wouldn't worry to much about the welds since thats a big part of how it was done back then. No doubt they have proven there worth for many years and smoothing them out would only remove Rays way.It also proves it's roots in the spirit of competition and how it was "really" done back then.
__________________
http://www.hotrodchat.com/gallery/ 17000+pictures on 25 pages and 118 albums and growing-
Old 10-02-2009, 05:18 AM   #20
Stovebolt
Senior Member
Stovebolt's Avatar
Thanks for the great story and the update Chris.
__________________
Doing all I can to keep 'em inline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
