THE H.A.M.B.
THE H.A.M.B. (http://www.jalopyjournal.com/forum/index.php)
-   Hokey Ass Message Board (http://www.jalopyjournal.com/forum/forumdisplay.php?f=5)
-   -   392 Flywheel on a 331 Hemi (http://www.jalopyjournal.com/forum/showthread.php?t=3208)
laverda 10-21-2003 06:55 PM
Does anyone out there know if a 392 flywheel will work on a 331 hemi (extended bell)? I currently have a PowerFlite setup & would really like a third pedal in the cdan's future. Thanks.
eBay link to hemi flywheel
cadlights 10-21-2003 07:10 PM
Re: 392 Flywheel on a 331 Hemi
CHECK THE BOLT PATTERN ON THE CRANK, DOESN'T LOOK THE SAME TO ME.
cadlights 10-21-2003 07:11 PM
Oops, sorry didn't mean to yell.
cadlights 10-21-2003 11:27 PM
1 Attachment(s)
This is the bolt pattern on a 331 and I think 392 also.
check the offset on the two holes at the bottom of photo.
SKR8PN 10-22-2003 12:33 AM
I think it is the same bolt pattern that MOPAR has used on EVERYTHING since the creation of DIRT.........
laverda 10-22-2003 01:21 AM
I have been looking through Ceridono's book & the only passage I can find is ' ... stock hemi flywheels from '51-'58 mounted to the crankshaft with eight bolts & registered on the outside diameter of the crankshaft flange ... ' A 426 flywheel needs mods as it registers differently on the crank. Unfortunately I cannot get access to the crank any time soon ... distant storage & another tranny (Powerflite) is hooked on the end http://www.jalopyjournal.com/ubbthre...lins/crazy.gif
Then again HotHeads lists the following flywheels ..
Chrysler Flywheel - Aluminum - 13# '51 - '56
Chrysler Flywheel - Aluminum _ 13# '57 - '59
Thanks again for the responses.
Later,
papa al
laverda 10-22-2003 01:25 AM
While looking for crank info I came across this gem for inspiration ... 331 a runnin'
later,
papa al
cadlights 10-22-2003 01:43 AM
1 Attachment(s)
This be a 331 bored out 20 thousands. Its a 55 and that crank adapter was made for it. That is what your crank looks like.
Rocky 10-22-2003 09:11 AM
if you still can't get a look at your 331 crank and still need to know the bolt pattern, I can take a rubbing off the back of mine, [53 with extended block] scan it and e-mail it to ya..Let me know via e-mail.
Gotta love electronic technology.
Rocky 10-22-2003 09:21 AM
BTW, every hemi book I have says chrysler/dodge never put a manual tranny behind a 392 Hemi. May I assume you're working with an automatic?
I'm using a poly-head dodge truck stick flywheel [thanks again, Silent Rick] behind my 331. Seems to work ok but I don't have everything assembled yet.
laverda 10-22-2003 12:28 PM
Interesting point ... the closest manual trans might be the Fluidmatic auto/manual trans that everyone dislikes.
Further fuel ...
eBay listings for flywheels (caveat emptor)
331
http://photo.starblvd.net/~laverda_jota/2-2-3.jpg
392
http://photo.starblvd.net/~laverda_jota/2-2-4.jpg
... and they do look different (bolt pattern).
Nice hemi 'cadlights' http://www.jalopyjournal.com/ubbthre...lins/smile.gif
later,
papa al
Andy 10-22-2003 08:17 PM
My experiece is that every thing interchanges. I have used the 6 hole and the 8 hole flywheels. I think the 6 hole ones came from the FH 6's. I have used them on the Dodges and the Chryslers. I prefer the 6 hole ones due to their lighter weight. Some of the 6 hole ones came with odd ring geares but the ring gears from the Powerflight auto's can be removed and substituted onto the flywheel. http://www.jalopyjournal.com/ubbthre...lins/smile.gif
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
