Technical Early GM ignitions
Discussion in 'The Hokey Ass Message Board' started by Voh, Sep 1, 2015.
  1. Voh
    Voh
    I have a '41 that has the original ignition key set. My understanding is that this is just an on/off switch because of the foot starter pedal.
    What year did GM start having a off-on-start ignition?
    Thanks
  2. Mr48chev
    Hell if you are doing an engine swap just stick a push button starter button under the dash and call it good.
  3. squirrel
    Trucks with the Six engine didn't get a key start till 1960 (!) they still had the food pedal in 59 on standard shift Six cylinders.
  4. squirrel
  5. Voh
    Voh
    I had thought about the button. But the stock ignition has the flexible "conduit" and the end modified.
    Would the 49-52 cars have a start position?
  6. squirrel
    1949 was when they went to the dash button starter in cars. 53 first year of the key start.
  7. Hnstray
    Hnstray
    from Quincy, IL
    I'm thinking '53 or '54 for passenger cars........
    Ray
  8. junkyardjeff
    junkyardjeff
    If you are going with a newer motor and want the key start a mid 50s Olds ignition switch will go right in the dash and have start along with accessory positions,I used one from a 53 Olds in my 37 Chevy and had it rekeyed to my original 37 key. Since I was still running a 235 I rebuilt a foot stomp starter and installed it so now I do not use the start position on the switch but glad I am using the 53 switch since I can turn it to the accessory position to listen to the stereo since I do not think the original switch had it.
  9. squirrel
    Or use a 53-56 chevy car switch, or a 55-59 chevy truck V8 switch.
  10. Voh
    Voh
    I was thinking one of these. But sounds like it was still just a on/off.
  11. squirrel
    any of them thru 1952 will NOT have the start position.
