Log in being dropped....
Discussion in 'Questions & Suggestions' started by denis4x4, Jul 21, 2015.
  1. denis4x4
    denis4x4
    from Colorado
    ......every couple of minutes. Have to log in before I can even finish reading a thread. Using an iPad. Had to log in again to even post this!!!
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Did you hit the remember me box ?
    If not, try that.
    Depends on your carrier, depends on your signal........ some Apps are a issue and not suer freindly depending on what program you are using and have to use your PC.
  3. I have been having this issue for a long time now. I check stay logged in and no difference. Good luck
  4. general gow
    general gow
    MODERATOR
    try clearing your browser's cache. that is usually the cause.
  5. Clear it all the time does not change anything.
  6. general gow
    general gow
    MODERATOR
    hmmm... maybe ryan will chime in.
  7. You are using the app?
  8. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I'm betting a APP issue.
    If you have a PC at home try it and see what happens.
  9. denis4x4
    denis4x4
    from Colorado
    No issues with the app on an iPhone. Laptop is not a problem....Actually the app on the iPad works...just unable to stay logged in on the regular HAMB site, including the OFC and Fordbarn.
  10. Paul
    Paul
    Editor
    I was having a similar issue after I upgraded the software in my phone,
    I logged off, cleared the cache, logged back in and the phone asked if it should remember the password, opt yes always.
    Seems to be working fine now, quicker and stays logged in.
  11. gerard
    gerard
    from midwest
  12. gerard
    gerard
    from midwest
  13. Yummy
    Yummy
    I'm having the same problems, I'll look at the suggestions, but I'm wondering if there is a setting to allow a time period to keep you logged in. I'm on a PC and I'm logged out automatically every few minutes.
  14. denis4x4
    denis4x4
    from Colorado
    Had to log in 5 times to post a new thread using the regular site. Finally posted on the app.
  15. I've been knocked off 3 times today,I cleared everything,checked the keep me logged and and everything seems to be ok now. HRP
  16. denis4x4
    denis4x4
    from Colorado
    Three attempts to log in failed. Like yummy, I've done all the tricks to no avail.
  17. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Are you guys logging in from Apps or PC's ?
  18. Paul
    Paul
    Editor
    my pc's work fine, no issues
    never used the app, use my phone straight like a pc
    still a bit slow but haven't been timed out for a while
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    My PC works fine as well - no issues.
  20. Laptop. HRP
  21. denis4x4
    denis4x4
    from Colorado
    iPad......lap top ok. Tried posting a new thread using the regular website and was bounced 3 times using the iPad and app
  22. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I've personally found........
    I pads and laptops just don't work worth a shit sometimes.
    I've NEVER had a problem with a PC
    I work with a IPad with work and a Smartphone with work and they kick me off now and then and don't work worth a shit sometimes.
    It is what it is fellas......
    iPads and smartphones are inconsistence so knowing that when it doubt....PC ........ and I've NEVER had it kick me off.
