Replacing some pieces of the "subfloor". Should this be coated with something? Original stuff I'm leaving doesn't look like it ever was, will have carpet glued to it later.
Start with pressure-treated wood, then coat with exterior paint before applying rubber or carpet. Just my two cents.
Since it will be covered , it won't hurt anything to paint or use a preservative on it . That will help make last longer. Go for it! ......................... Jack
http://www.jalopyjournal.com/forum/threads/49-olds-wagon-ive-been-working-on.966335/#post-10880996 Thank's for the suggestions guys!
