Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. BrerHair
    BrerHair
    Well, there you go. That dangle looks the same to me. Great pic.
  2. greybeard360
    greybeard360
  3. jivin jer
    jivin jer
    Eric H likes this.
  4. Do you have two solenoids per door hooked up?
    Von Brush likes this.
  5. jivin jer
    jivin jer
    I've never had cars with electric doors before. This has produced some paranoia about electrical failure. The added cable is to be able to mechanically activate the door latch. I need to clean things up a bit and snap a pic.
  6. That's a good move. I need to add an auxiliary cable to mine as well and keep forgetting….
  7. bobo1
    bobo1
    from France
    Very very nice job Jer , what are you going to do with the grille ?
  8. How have you set up the "emergency" access the extra cable?
  9. jivin jer
    jivin jer
    Here's the emergency cable.
    Bo Bo, the original pic in the post #1949 confirms that the grille (front) is correct. This will become more obvious with the duplicate pose's that I'll do shortly. I need some sun, and maneuvering this thing around is not very friendly. 001 (7).JPG
    RICH B likes this.
  10. bobo1
    bobo1
    from France
    oups , sorry I don't see it , very good edea for the cable
  11. jivin jer
    jivin jer
    With "things" percolatin', and waiting for some sun, lets do the dash knobs.
    Prior to this I've had some limited experience with this plastic stuff. I won't be able to say that after all this.
    This has taken a lot of thinkin', making mistakes, and finding out what won't work.
    This is a look at the goal, and what we start with. P2270014-vi[1].jpg 001 (3).JPG
  12. jivin jer
    jivin jer
    This is a better picture of the dash. The spotlight handle is visible, PA230159-vi[1].jpg 004 (3).JPG as is the dash knobs. I sent Jesse a drawing of what I thought they looked like, his reply was "yup". Original pics courtesy of (guess who?) Rik Hoving.
  13. BLUDICE
    BLUDICE
    What's hanging from the rear view mirror??
  14. jivin jer
    jivin jer
    I get energized by a question like this. I spent about 45 minutes on the web looking for something that would look correct. I'll ask Jesse if he can give me a clue to work with.
    This shows the plastic cut into strips, there's 3 of them ( not 2). They're glued together to get the width that's needed. The rough knob shown would represent a failed attempt to get it right. When you try to make a cut with an air saw everything melts back together when you think you're done. I had to cut the plastic with a fine tooth, sharp hand saw. 007 (2).JPG 008 (3).JPG 004 (6).JPG
  15. Peanut 1959
    Peanut 1959
    Watching and learning.
  16. Torchie
    Torchie
    Not to hijack this thread.....
    There is a great how to do article on making these knobs in the 2nd issue of the new custom car magazine "Traditional Kustoms" They also list sources for materials.
    Now back to you Jer.......
    Torchie.
  17. jivin jer
    jivin jer
    The cheapie miter box saw was excellent for nice, clean, straight cuts. 004 (2).JPG
  18. BrerHair
    BrerHair
    And the plastic is filled with . . . ?
  19. Neat idea. How did you set up the angle cut on the knob blanks; doesn't look like one of the fixed angles built into the miter box.
  20. jivin jer
    jivin jer
    008.JPG The plastic is pieces of green Lucite glued together. Nothing in the middle on these. I just carefully cut that angle by hand. When it comes to the shaping part there is some wiggle room.
  21. can't wait to see some finished knobs....
  22. CadMad
    CadMad
    Show us your knob !
  23. banditomerc
    banditomerc
    What dedication....you're not take a holiday break ,are you?
  24. jivin jer
    jivin jer
    A failed attempt that also tried to see what would, and wouldn't work. I will probably take a short break. 001 (13).JPG
  25. jivin jer
    jivin jer
    003 (9).JPG 002 (12).JPG I need to be able to drill these knobs to fit on the window crank handles. Getting them perfectly straight isn’t as important as the dash knobs. I thought I could get them close enough by hand. I was wrong. I need to be able to drill these knobs to fit on the window crank handles recepticles.
    I really needed to find someone with either a lathe or a drill press. I wasn’t able to find either one.
    I solved this problem by finding a Northern Tool drill press and vise for less than a hundred dollars. I really don’t expect much out of this set up, but it sure does solve this problem.
    Peanut 1959 likes this.
  26. Torchie
    Torchie
    There are times when a "Cheap" tool can do the trick.
    Looking good Jer.
    Torchie
  27. money well spent ! bingo !
  28. jivin jer
    jivin jer
    daddio211, nelson845, Eric H and 2 others like this.
  29. Merry Christmas Jer!
  30. BLUDICE
    BLUDICE
    X 2 to you Jer
