I somehow must of misfiled/deleted it. It's a file of pretty much all engines both US made and foreign probably had 100+ engines listed. I'm trying to find the weight difference between a Ford FE with aluminum heads and intake vs a Lincoln V-12, 1948 vintage. With removing the power brake booster and all of the hydraulic power window mechanism and the banjo housing & torque tube etc..I've already cut out over 200#. I do know the weight of my FE. Thanks >>> Movin/on .
Why is it important to know at this point? if you assemble the car (mock up), weigh it, each axle separately, and you'll know what I suppose you are trying to calculate. As an opinion, worth as much as you are paying for it, the V12 is probably about 650-700lbs with flywheel and all accessories. Best wishes on your project. Ray
http://www.bacomatic.org/~dw/library/txt/engfyi.htm I recommend everything at http://www.bacomatic.org/~dw/index.htm for anyone who needs some food for thought.
Zerk: Thanks for the link. That's the one I had Guess I only printed it out and couldn't download it. Now I've saved it as a favorite. Richard
Seems Lincoln V12 is not listed. Many weights seem 'close enough', others are inaccurate, but it's quite an interest and useful guide nonetheless. Ray
